M4CKK wrote:top banana...... I'd be afraid to use it![]()
Where are you going to use it first??
misty wrote:that fella of yours,
needs to come and line my van for me,
how has he managed to get the shape on them doors????
andy
foxi wrote:What curtain rail did you use?
misty wrote:Hi Andy,
It's Paul here. I think the top cab cupboard is my "piece de resistance" In total it must have taken me a bit less than a week to do! but it looks really good. This was also the point where I realised why people tend to use VW's As Transits got more curves on the inside than J-lo! It took a few hours of brainstorming before I came up with a method.
First I glued a few short battens to the roof (to make the curve) and filed in between with 25mm celotex. Then I 've put up a piece of plastic ( the Polyethelene stuff we used for the damp lining) and used double sided tape to stick it to the roof and used a marker to mark the contour of the roof on the plastic. This piece I later used as a damp lining for the top of the cupboard.
This I cut out and transferred onto a piece of 4mm triplex that I found lying around.this was still bendy enough and did the same for the sides, and tried to make it fit.
It took about three triplex templates to get the shape right. I used the side bits to keep the top board in place, and applied plenty of pressure to the top to get it curved. Don't forget to mark on the bottom where your battens are on the roof, as you need them to screw the top onto, with some serious screws. You don't want to get these through the roof! After the fit was done we carpeted the panels and fit them in again.
I'm afraid that there are no photo's in existence of this part of the build, as we never intended to put the building process on the web. I is worth it, albeit very frustrating at times.
I hope this helps
rachelemily wrote:Hi Andy,
Nice work! Is the conversion complete now?
We took our camper abroad for the first time in September to France for 2 weeks and it ran like a dream so v happy(especially after a tune from Martin at van tuner!)
