water pump?
water pump?
Postby staffy31 » Thu Aug 23, 2012 7:50 pm
can anyone tell me what size and kind of water pump i will need for a camper, from water barrel to taps
cheers
staffy31
Re: water pump?
Postby Anton2k3 » Tue Aug 28, 2012 6:06 pm
I'd recommend a pressurised system. Check out the shurflo pump range. I have the 12v 30psi, which manages all water requirements in our van with ease. Can use any taps you like with a pressurised system, and there are no switches etc between taps and pump with this. Pressure switch is built into the pump too, so just hook up 12v feed, and thats it!
Anton2k3
Re: water pump?
Postby staffy31 » Tue Aug 28, 2012 7:17 pm
Anton2k3 wrote:I'd recommend a pressurised system. Check out the shurflo pump range. I have the 12v 30psi, which manages all water requirements in our van with ease. Can use any taps you like with a pressurised system, and there are no switches etc between taps and pump with this. Pressure switch is built into the pump too, so just hook up 12v feed, and thats it!
thanks anton sounds like im gonna need abit of pressure with this kind of tap so might be a good idea il try upload a pic of the tap
thanks :D
staffy31
Re: water pump?
Postby staffy31 » Thu Sep 06, 2012 6:27 pm
i finaly got a whale pump so now just need to pipe it up but think im gunna need some of that twine that goes round the pipes but thing is does it work on flexi pipe :) :lol:
staffy31
