DarrenK wrote:So does this mean, i fit it from the Main battery through to the Leisure battery, and disconnect the two existing cables leaving just the relay ones?
If so, then it seems to be very quick and eas fix, and no cables running up to the stearing column or alternator.
Yeah, basically you tap the 'sense' ie 5v at the alternator to relay/processor(connector will be in kit) and run the relay/processor wiring between the batts.
Then you run a cable to the fridge from leisure batt @15A guage and another say 30A guage to your fusebox for all the pumps/lights etc.
Put fuses for everything as close as possible to batt positive terminals.
I do not even have the clock or vehicle alarm ultrasonics running from main batt, ie. zero draining when static. An unregulated 5-10w solar panel is handy to charge maintain the leisure battery when idle.
You will get instructions/diagrams with the kits and the two places suggested offer advice etc. it's a doddle really, just check and make sure every circuit in the van ie. lights/stereo/pumps are individually fused with the correct rated fuse/wiring and choose a fusebox feed wire guage to suit - ie. total everything and double it
I treated my MK2 amby camper to a pair of american rv plumbing type surface mounting solar vents last week as the original passive ones were past their 27 year sell by date, it makes a big difference having a positive extraction of air every day and they cannot be heard running........$21 a pop in sale promo
