finally got me taps..
Postby staffy31 » Mon Aug 27, 2012 5:05 pm
hi guys finaly got my taps for the camper ther great bargain from the carboot brand new mixer tap only 7quid so just need the pump next anyone reccomend any thanks :lol:
staffy31
Re: finally got me taps..
Postby fidget » Mon Aug 27, 2012 5:23 pm
i had a pump like this in my camper. they preasure up and stop. when you open the tap it will start to run. makes your tap work like the ones at home, no switch needed at the tap.
http://www.ebay.co.uk/itm/Automatic-Fre ... 589433b279
my advise may not be right, but I like to give my 10p worth, and an answer even if wrong is nice to see.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
5-Speed Manual - MT75
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby staffy31 » Mon Aug 27, 2012 5:34 pm
fidget wrote:i had a pump like this in my camper. they preasure up and stop. when you open the tap it will start to run. makes your tap work like the ones at home, no switch needed at the tap.
that sounds good friend but will it power a home mixer tap?i bought a water barrel from the carboot for the cold but the hots comin from the old water heator at the front whatthe workman used to use just need to get it going agen ha..
:lol:
staffy31
Postby fidget » Mon Aug 27, 2012 5:44 pm
i used one of these pumps recently in a home, fitted a shower that was to run from a header tank, but it had a negative head at the shower, so fitted this pump, but a little bigger, held presure at 2 bar, water was fed from tank to pump then split into 2 , 1 for hot, that was heated through an inline electric water heater, and the 2nd for the cold, for taps and mixer shower and toilet, worked well. that was running from a maplin 13.8 power supply for a c,b. will find a pic and put it up.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby staffy31 » Mon Aug 27, 2012 6:20 pm
fidget wrote:i used one of these pumps recently in a home, fitted a shower that was to run from a header tank, but it had a negative head at the shower, so fitted this pump, but a little bigger, held presure at 2 bar, water was fed from tank to pump then split into 2 , 1 for hot, that was heated through an inline electric water heater, and the 2nd for the cold, for taps and mixer shower and toilet, worked well. that was running from a maplin 13.8 power supply for a c,b. will find a pic and put it up.
thanks man but im gonna be powerin mine from a 12v leisure battery do you think that wud be ok hot comin from the water heator at the frnt and cold was gonna install a water barrel underneath :D
staffy31
Postby fidget » Mon Aug 27, 2012 6:31 pm
the pump is designed for use with a battery so it will be fine from a leasure battery, it you are running hot from one tank and cold from another then you will need 2 pumps, 1 for each, the one i had in my camper (camper was actually an old coach that had a 60 gal tank in the boot.) was fed from the tank, then split to go to a gas water boiler (type now illegal, to sell) and then to the tap/shower and the other split to the cold tap/shower.
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
Postby staffy31 » Mon Aug 27, 2012 8:29 pm
thanks mate a wonderd how do the taps know its hot or cold
regars dude
:lol:
staffy31
Postby staffy31 » Mon Aug 27, 2012 9:21 pm
fidget wrote:the pump is designed for use with a battery so it will be fine from a leasure battery, it you are running hot from one tank and cold from another then you will need 2 pumps, 1 for each, the one i had in my camper (camper was actually an old coach that had a 60 gal tank in the boot.) was fed from the tank, then split to go to a gas water boiler (type now illegal, to sell) and then to the tap/shower and the other split to the cold tap/shower.
do you think i should rder 2 pumps for hot and cold :))))
thanks man
staffy31
Postby staffy31 » Mon Aug 27, 2012 9:22 pm
class coachbuilds dude wish i went to the summer solistice in one ha :lol:
staffy31
Postby suffolkboi » Tue Aug 28, 2012 1:25 pm
How would one of these auto pumps compare to a Whale Pump? In regards to flow and pressure?
Mk5 Camper build - Work in progress
viewtopic.php?f=58&t=104595
suffolkboi
Postby staffy31 » Tue Aug 28, 2012 5:08 pm
suffolkboi wrote:How would one of these auto pumps compare to a Whale Pump? In regards to flow and pressure?
a whale pump sounds powerfull :D
staffy31
Postby Anton2k3 » Tue Aug 28, 2012 6:00 pm
I have used a similar pump to above, shurflo 12v 30psi. Works on an inbuilt pressure switch, so no wiring of micro switches from taps etc. Just turn tap on, pump senses pressure drop, and turns on.
Regarding hot and cold. We have the pump on exit from fresh water tank, it then t's off into a hot and cold line. Cold goes straight to taps, hot goes through a calorifier.
Anton2k3
Postby staffy31 » Tue Aug 28, 2012 7:50 pm
cool thanks for the info bearingin mind mines only a weekend camper type and i have a water heator at the front and gonna install a seperate water barrel for cold so but the taps i bought are household and looks like they would need abit of pressure so wel see .. :roll:
staffy31
Postby staffy31 » Tue Aug 28, 2012 7:56 pm
figet that sounds class was it like an old bus lol
thanks man
staffy31
Postby fidget » Tue Aug 28, 2012 10:35 pm
thanks man
lol it was. an old bedford PJK 24 seater, about 25' foot in lengh, had full range cooker, full size kitchen sink, shower, toilet, sleapt 8 people, and even had its own twin tub washing machine, its own 2.8 kva gen hooked underneath, was self contained, a true glasters bus, loved it, but it came far to exspencive to run it, really wish i still had some pics of it, but i lost all when i had a break in and they took the computer, the coach i can still find on google maps, has been well stripped, it is located just outside barton devon, at a gipsy yard, ( true gipsys, nice people,, they are not all pikeys, lol)
and yes in your case you will need 2 pumps as you are feeding from 2 different tanks. 1 for each going to its own tap,
as said above, these pumps work on a preasure switch mounted within the pump. they are the same as the whale pump, but a fraction of the cost, but one thing is true in this world, you get what you pay for, whale are one of the best and it will last, a cheeper one will work just as well but may only last a few years,
Build: 05.03.1992
Series: 100L
Diesel 2.5 (70PS)
Drive: RHD RWD
Axle: 4.56
Diamond White 73
fidget
