fidget wrote:if you are on about the spot lights for your home that sink into the ceiling, then most of the bulbs for them are 12v anyway, they run thru a transformer in the home, as for how long your battery would last, it would depend on how many spot lights and what wattage you use, cheep ones are normaly 50w bulbs, 20w bulds give less light but the battery will last longer from charge to charge.
fidget wrote:the led ones are good, very low enery use, only about half a watt, the light they give off is not as good as halogens but in a van they are great, also you can change then for color changing led bulbs, BUT i have not seen any in 12v, but not really looked either. lol
as for just taking the transformer off ant using the lights, yes you can as they are wired in paralel, but check the wattage on the bulbs, most are supplyed out the box with 50w buld, in a line of 3, that would be pulling 150watts from your battery, that would be like leaving your headlights on,
staffy31 wrote:i went to go outdoors they said you can get a inverter 240-12v so should be able 2 use 240 downlights neebother just need to see how much what am ganna use becuase the cheapest inverter is 500watt output so run me lights of that and everything else to the battery should be spot on anyone open to sugestions
