fridge cooling fan ?
Postby hilliebilly » Mon Sep 03, 2012 10:42 pm
i having cooling problems and with the great internet i found putting a pc fan behind the fridge to use as extra cooling
but i dont wont it to be on all the time and dont wont to be turning it on and off
is there a temp thingy i can wire in if what it is it ive been scratching me head and cant come u with it
hilliebilly
Re: fridge cooling fan ?
Postby whitemice » Tue Sep 04, 2012 12:11 am
It will tend to be warmer air during the day so i would suggest a 5w or 10w solar panel just wired to the fan will more or less auto adjust - fit and forget and costs nowt to run- a mono crystalline( these should run your fan even when cloudy) solid glass one is a 20 pound note on fleabay and a lightweight semi-flexible monocrystalline polyurethaned direct to roof or taped to window/side of van about 30-40 quid. You could also use it for battery maintenance when parked at home as no controller is needed up to 10w (25 quid) for the batteries we use. eg;
http://www.ebay.co.uk/itm/5-W-Monocryst ... 2249wt_919
http://www.ebay.co.uk/itm/10w-12v-Monoc ... _958wt_919
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby hilliebilly » Sat Sep 08, 2012 4:47 pm
where can i find a timer that will come on for a while then go off for a while and so on must be 12 volt
hilliebilly
Postby bigjohnthomas » Sat Sep 08, 2012 6:27 pm
thermotwat?
have a peek aound cpc dude they have loads of sh*t like that :wink:
http://cpc.farnell.com/unbranded/mk138/mk138-thermostat-mini-kit/dp/HK00813
bigjohnthomas
