zig cf9
zig cf9
Postby chasnjess » Wed Oct 03, 2012 9:09 am
Hi can somebody please explain please I have just bought a ZIG CF9 for my minibus conversion and it says to fit the new 12S supplementary plug and socket to van .
Is this the hook up or something entirely separate. I have got my round the wiring of the unit but this bit is throwing me.
Another question is that I was going to fit leisure battery into engine compartment, if the ZIG unit is fitted at the rear end of van should I fit the battery closer to the unit (does this matter)
Any help please.........Bruce
chasnjess
Re: zig cf9
Postby TIMO » Wed Oct 03, 2012 1:17 pm
A quick google bought up this :arrow: http://www.yoc4x4.co.uk/pdf/Ystradgynla ... Wiring.pdf.
I would imagine it best to have battery and zig close, as there will be less live wire routed through the vehicle .My caravan has all the main stuff like that in close proximity.
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Re: zig cf9
Postby MinorMatt » Wed Oct 03, 2012 1:41 pm
12S socket is a trailer auxillary socket which powers things like fridges from the towing vehicle battery. It the grey towbar socket.
Re: zig cf9
Postby TIMO » Wed Oct 03, 2012 1:44 pm
MinorMatt wrote:12S socket is a trailer auxillary socket which powers things like fridges from the towing vehicle battery. It the grey towbar socket.
cant see why he needs that on a camper though.
TIMO
Re: zig cf9
Postby MinorMatt » Wed Oct 03, 2012 1:58 pm
I have seen several campers towing caravans...
Re: zig cf9
Postby TIMO » Wed Oct 03, 2012 2:02 pm
MinorMatt wrote:I have seen several campers towing caravans...
Metoo just dont see how he has to fit this first to make his zig work in a motorhome :mrgreen:
TIMO
Re: zig cf9
Postby whitemice » Wed Oct 03, 2012 2:35 pm
The zig will be charging the leisure batt. so to get minimal voltage drop in your case betwixt them i would use at least 4mm sq cable, 10m of this should cover it,
http://www.ebay.co.uk/itm/Free-MC4-conn ... 238wt_1394
Unless towing i would cut out with scissors the bit about 12s socket and roll a fag with it.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Re: zig cf9
Postby chasnjess » Wed Oct 03, 2012 11:09 pm
Yep it was me with the silly question . It was referring to trailing a caravan .Read the next page after posting question . At least your comments made me read it properly
Thanks ....................Bruce mmmmmm I mean Bruces wife!!
chasnjess
Re: zig cf9
Postby chasnjess » Wed Nov 21, 2012 10:17 am
whitemice wrote:The zig will be charging the leisure batt. so to get minimal voltage drop in your case betwixt them i would use at least 4mm sq cable, 10m of this should cover it,
HI THANK YOU FOR REPLY ,I DO NOT HAVE SOLAR PANELS SO CAN THIS SOLAR CABLE BE USED FROM MAIN BATTERY TO LEISURE BATTERY.
I DONT QUITE UNDERSTAND AS ANY PRICES FOR MAIN BATTERY TO LEISURE ARE VERY EXPENSIVE CMPARED TO THE ONE YOU HAVE RECOMMENDED.
AGAIN ANY MORE HELP APPRECIATED ........BRUCE
chasnjess
