Installing my microwave.
Postby ajpmsport » Wed Oct 10, 2012 11:09 pm
Hi, i would like to put my 12 volt microwave back in the van, high up on a shelf (when its made) Is there any reason why i can`t take the negative side and earth to the side of the van high up, rather than run an earth cable down the side of the van and earth it down low. (The batteries will be directly below .)
I have made a removable access panel, this is where the microwave is going to sit on a shelf. I made it possible to have access to the lower panel at the floor where the batteries will be going.
I hope this makes sense, :!: THANKS
ajpmsport
Re: Installing my microwave.
Postby knighty1981 » Thu Oct 11, 2012 12:09 am
you could earth it to the body.... but for the power the microwave will be pulling you'll be better off running a wire down... especially when the batteries are right below
how many watts is your mircowave ?
knighty1981
Postby whitemice » Thu Oct 11, 2012 12:25 am
Not a fan of high level because of safety/scalding etc
Would choose fused direct wiring in your instance though..
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby ajpmsport » Thu Oct 11, 2012 7:10 pm
knighty1981 wrote:you could earth it to the body.... but for the power the microwave will be pulling you'll be better off running a wire down... especially when the batteries are right below
On the data plate it says : 750 watts output 450 watts
ajpmsport
Postby ajpmsport » Thu Oct 11, 2012 7:20 pm
whitemice wrote:Not a fan of high level because of safety/scalding etc
As the van evolves and the sides and everything else gets done if i have space it will go lower. I quiet agree about the high level, just another dilema with making a decision. The van is sort of cut in half by the second row of seats, they take up alot of room really. Its that age old situation of transporting kids having seats that fold flat and still retaining seat belts. :?
ajpmsport
Postby knighty1981 » Thu Oct 11, 2012 8:16 pm
750watts at 12volts = 62.5amps.... use nice thick cable for that... something like starter motor cable :)
knighty1981
Postby ajpmsport » Thu Oct 11, 2012 10:33 pm
knighty1981 wrote:750watts at 12volts = 62.5amps.... use nice thick cable for that... something like starter motor cable :)
Nice one THANKS :wink:
ajpmsport
Postby ajpmsport » Thu Oct 11, 2012 10:44 pm
Just noticed my van in the picture below of how it used to be as a (Jarvis) rail van. At the bottom is the heated hand wash, above this a control box with all the switches, then a hot water boiler. Which at the time had the hot water tap in reaching distance from the kids in the booster seat next to it , so when they were in the van i never switched it on, then the microwave at high level ! I did use it and found it to be ok i guess, just for pies and pizzas ect. All the healthy stuff. :lol:
ajpmsport
Postby ake » Fri Oct 12, 2012 11:20 am
For the load required wire it directly to the battery
Postby fortyeight » Fri Oct 12, 2012 1:17 pm
hi i suspect the microwave is 240v how is it going to run on 12v, if it is will you let me know how and ill do it to mine ,JUST SEEN IT IS A 12V MICROWAVE where do they sell 12v ones cheers
fortyeight
