gas pipe compression fittings
Postby Rickbu » Thu Oct 25, 2012 11:06 pm
can anyone help me im having such a hard time.. i am doing the gas on my self build camper and i just cant seem to get all the compression fittings to be gastight . if i attatch the u gauge i can see the pressure dropping down fast enough to loose about 1 microbar per minute . if i pressurerise the lines with my compressor and try use gas leak detector on them i get some very fine bubbles on some of the fittings. tightening them doesnt seem to help . im wondering if i have over tightened them and now need to make the ends of again so i ordered some more olives. are there any tips anyone can offer me?
one thing im wondering is if the 8mm copper pipe i ordered is cheap and too thin... it seems to kink and deform very easy wheras some pipe i took from an old caravan i broke is so tough its hard to form in the shape you want
anyway if anyone has any tips on getting a good seal using the compression fittings please help.. im starting to wonder about using solder joints. at least i know they will be ok.
Rick
1998 county X2 one daily use one waiting restoration
2000 mk5 self build motorhome restored and built
1995 Isuzu trooper 3.1 td
2000 astra 1.7 td Isuzu power conversation
Rickbu
Re: gas pipe compression fittings
Postby whitemice » Thu Oct 25, 2012 11:56 pm
i reckon you are over-tightening them as most do., also only use copper olives. Some pipe is monkey metal though-i buy from local caravan workshop.
this may help.
http://www.thomson-caravans.co.uk/advic ... itting.htm
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby g-man » Fri Oct 26, 2012 9:29 am
get a mini (6/8/10mm)bender
g-man
Postby AK » Fri Oct 26, 2012 1:55 pm
Yes as already mentioned don't over tighten them,
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
Postby misty » Fri Oct 26, 2012 7:46 pm
you have probably over tightened them, hand tight and a quarter turn is all they need, any how you have done it now if you can't replace it get some calor tight comes in a tube from plumbers merchant, there is another one we use clesse tight i think its called, i always paste my joints with it,
hope it helps
misty
misty
Postby Rickbu » Fri Oct 26, 2012 11:57 pm
i ordered some more olives so i can remake the ends. is that it? hand tight and quarter turn?? its hardly anything.
i thought i was over tightening.
what do you do if it hasnt sealed after the quarter turn. tighten more? or what
Rickbu
Postby whitemice » Sat Oct 27, 2012 12:51 am
Yes, it's a kind of feel thing.
eg. the fridge/freezer in my van has been in/out 5 times for servicing in 20 years-same olive/conn.
Do your drop test and tighten until it seals, no more. Drop test once a year at start of season- minimum.
whitemice
Postby ake » Sat Oct 27, 2012 9:25 pm
Put some gas tite on the pipe ends and olives before you put them together, then hand tighten, then a quarter turn, then test, and tighten another quarter if it leaks
Postby Rickbu » Sun Oct 28, 2012 6:17 pm
its driving me nuts this . i have leak detector. i have gas seal non setting compound( but i didnt try to use it yet) . i just cant find the leak! im starting to wonder if there is a perforation in the pipe somewhere. it seems no matter what i do i cant fix the leak. i cant find any leaks with the detector fluid but i can see a pressure drop over a few minutes...
solder fittings?
Rickbu
Postby ake » Sun Oct 28, 2012 7:06 pm
Rickbu wrote:its driving me nuts this . i have leak detector. i have gas seal non setting compound( but i didnt try to use it yet) . i just cant find the leak! im starting to wonder if there is a perforation in the pipe somewhere. it seems no matter what i do i cant fix the leak. i cant find any leaks with the detector fluid but i can see a pressure drop over a few minutes...
solder fittings?
Solder fitting are not allowed on campers/caravans
Take apart every fitting, paste it and reassemble, then test it again. Are you sure your appliances are not leaking?
Postby Rickbu » Sun Oct 28, 2012 8:27 pm
well i have isolation valves on every appliance and am testing with them turned off. if i get to hold pressure in that state then ill test with them turned on
is it ok to use the paste on the fittings? a lot of people say they should be dry?
Rickbu
Postby ake » Mon Oct 29, 2012 8:03 am
I always paste fittings.
Postby Rickbu » Thu Nov 01, 2012 10:50 pm
right pasted all the fittings. still have pressure drop. even with all the gas taps at each appliance turned off. thinking about ripping it all out and starting again with some better qaulity copper pipe from b&q. ( i got this pipe cheap over the internet) . i have no idea where the leak is and feel like im banging my head against a brick wall.. im just throwing money at the problem now hoping it will go away. could the regulator be leaking or should that hold the pressure in the lines when not on the bottle... i have no idea what else to try now..
Rickbu
Postby misty » Thu Nov 01, 2012 11:08 pm
Rick are you saying that you have the regulator connected or not? It might pass if it is not connected to the cylinder try it connected, in all my time I have never come across a leaking copper pipe, only fittings and regulators, how is the reg connected to your system? Flexi hose check that with soapy water, that could be the place to start,
Hope it helps
Misty
misty
Postby whitemice » Thu Nov 01, 2012 11:32 pm
Are you doing your drop tests with the regulator fitted?
Do the drop test at the flexi hose without regulator.
As stated use washing up liquid in water, with gas on, at all your joints/taps/regulator.
whitemice
