Shower tray suggestions
Postby Ivan Dobski » Mon Oct 29, 2012 2:05 pm
Gents,
Looing for some idea's changing the layout of the campervan just now and wont get the shower tray from the caravan I'm using into the layout as I've got about 4.5ft left till the end of the van. I've still to get a rasied double be into that space as well planning on it being about 4ft above the floor.
Now I'm prepared to loose about a 1-1.5ft from the bed to accomodate the shower, Any idea's on what to use for the floor? Doesn't need to be a caravan shower tray just something around 500mm wide max . My plan was to cut down the shower tray floor and use some perspex that I can lay my hands on and silicone it around the floor.
Any other ideas must be cheaper than cheap as chips.
I'm the meatsaver murderer only I never done it. I only said I done it so they'd take my bellend out of the Magimix.
Ivan Dobski
Re: Shower tray suggestions
Postby whitemice » Mon Oct 29, 2012 2:57 pm
If space is too tight for a shower tray/cubicle I would leave it out, campsites have showers and if desperate then a wet flannel does the job.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Ambowelly » Mon Oct 29, 2012 3:17 pm
I have a similar dilemma with my camper/ambulance as the wheel arch protrudes into the shower area..
My options are:
Cut down the donor shower tray and reseal.
Cut down the donor tray and use as a mould to copy in fibreglass.
Use fibreglass straight into the area and seal it in.
Custom make a tray out of stainless steel and bond that in.
If the shape is very complex, I'll be laying clingfilm into the shower tray area and lining it with fibreglass and then sealing it in with silicon sealer. If it's not too tricky, I'll be folding and welding one out of stainless.
Ambowelly
Postby whitemice » Mon Oct 29, 2012 3:45 pm
Acrylic one here is small as they go.
http://www.ebay.co.uk/itm/Caravan-Motor ... %26ps%3D54
whitemice
Postby jonochap » Mon Oct 29, 2012 3:53 pm
I have to say im with whitemice...best to have a loo and a drop down sink...but its a choice thingy
I would recommend not to use stainless, it will be cold, slippery and possibly not earthed...heat transfer and electrical shocks
I would strongly consider getting a wet room floor with altro fitted by a specialist. To my experience in making wet rooms in buildings with limited space, this has always been the most successful solution esp if the floor area will not accommodate a uniform shape.
Consider aus board similar (not wdp it doesnt work) for the walls...once that baby starts leaking its gonna be a mare to track it...a tray works best if pos though..
Owner of not so troubled puk :)
jonochap
Postby Ambowelly » Tue Oct 30, 2012 12:16 am
Seriously?? A layer of insulation under it, and a rubber waffle in it to sort cold and slippy. Possibly not earthed? If it would cause you a sleepless shower, earth it! Quite why you'd want to is a mystery unless you take the toaster in there. Heat transfer....from what, to what?
FWIW, I've also been told that a shower is a waste of time as folks rarely use them. I've also been told a don't need a van, a bike, a kit car, a motorhome or a big house. These are all true but I want them. And a shower... :wink:
Ambowelly
Postby jonochap » Tue Oct 30, 2012 12:18 am
FWIW, I've also been told that a shower is a waste of time as folks rarely use them. I've also been told a don't need a van, a bike, a kit car, a motorhome or a big house. These are all true but I want them. And a shower... :wink:[/quote]
And im sure you shall ;)
jonochap
Postby whitemice » Tue Oct 30, 2012 12:20 am
I tow a bath with my bike and sleep in it.
whitemice
Postby TIMO » Tue Oct 30, 2012 12:23 am
whitemice wrote:I tow a bath with my bike and sleep in it.
:lol: :lol: :lol:
Seriously though,, why not grab a shower/bog/sink combi out one of Clarksons " roadtested " caravans ... compact and bijou and do everything you need :idea:
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby whitemice » Tue Oct 30, 2012 12:30 am
:lol: :lol: :lol:
Would save getting caught rinsing your tackle in a river.
whitemice
Postby ursus » Tue Oct 30, 2012 10:14 am
I enjoyed washing my tackle in rivers in Spain+Portugal,lovely and warm compared to here.Good job no fish wanted to bite :lol:
ursus
Postby Ambowelly » Tue Oct 30, 2012 10:59 am
I washed my tackle in a freezing cold Loch. Thankfully I had a nice hot shower to warm me up and wash off the rotting debris that was stuck to me.... :shock:
Ambowelly
Postby redvendave » Wed Nov 28, 2012 10:53 pm
olearys do wheelarch shower trays and most motorhome parts suppliers have various ones just google it
redvendave
