help! relay wire leisure bat-alternator
Postby staffy31 » Tue Nov 13, 2012 9:31 pm
can anyone tell me how to join them relay wires from leisure battery to alternator please :D
staffy31
Re: help! relay wire leisure bat-alternator
Postby ake » Tue Nov 13, 2012 9:34 pm
On what van?
Postby transit120mick » Tue Nov 13, 2012 9:46 pm
Like this.
Mick
transit120mick
Postby staffy31 » Tue Nov 13, 2012 9:50 pm
me transit ex bt van now staffy camper av started it agen doing the laggin now carpets ready to stick on the morra but stil need to do me battery work i got one of them numark batterys from go outdoors av put that behind the seat inside a box but i havent wired it up yet so i got one of them relay wires that goes to the alternator :D :D
staffy31
Postby redvendave » Wed Nov 28, 2012 10:33 pm
a basic relay isnt a good idea , they burn out easily , i tried this route 100 amp relay ,100amp maxi fuses , relay lasted our 2weeks holiday ok when we next went away following weekend it just died .haveing looked into further its reckoned its relay chatter , as the relay is on and of all the time you stop and start engine . i have since fitted a intelligent relay , durite one £26 of ebay , this cuts in at out at set voltages, so is not constantly on and of everytime engine starts and stops , i have since had no problems , also use plenty of fuses to protect everything ,big enough for alternator output and leisure battery , and cables big enough etc
redvendave
Postby mjsroofing » Thu Dec 06, 2012 10:23 pm
I use a smart/intelegent relay in my van I run a few 12v items and a 1500w inverter with no problems.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby pepper » Fri Dec 07, 2012 1:00 am
I use the 200amp version (about £80 off ebay in mine) but I have a 3100w inverter!
pepper
Postby mjsroofing » Fri Dec 07, 2012 7:53 am
pepper wrote:I use the 200amp version (about £80 off ebay in mine) but I have a 3100w inverter!
Think is around 80amp, 200amp is a lot but u can't have to much I suppose.
There is a way to calculate how much amp u need to wattage and volts but I don't remember.
mjsroofing
Postby andycaca » Fri Dec 07, 2012 12:16 pm
i think its as simple as watts/volt = amp
so 100w / 12v = 8amp
2005 Mk6 Jumbo 2.4 115 350 aka "The Party Bus"
1988 Celica Sprint Special aka "The 500bhp Sledgehammer"© Fensport 2012
2003 KX250 aka "DeathWish™"
andycaca
Postby mjsroofing » Fri Dec 07, 2012 8:43 pm
andycaca wrote:i think its as simple as watts/volt = amp
Nice one
mjsroofing
Postby ake » Sat Dec 08, 2012 2:12 pm
Correct
Power (Watts) = Volts x Amps
Postby ajpmsport » Sun Dec 09, 2012 8:43 pm
If you put it into a "power triangle" all you need is two parts of the equation. Just cover over the part you need to find out.
Power(watts)
_______________
Volts x Amps
100
__________ = 8.3 Amps
12
It works every way round, just cover over the part you are trying to find.
ajpmsport
Postby andycaca » Mon Dec 24, 2012 9:14 pm
in related news, i fitted one of those smart voltage sensing relays at the weekend. very nice and tidy install with no need to go under the bonnet
i chose the lazy option and bought a kit but the only really special bit is the relay. everything else is just fuses and cable
the relay on its own costs about 30 quid where i have seen it online
http://www.ebay.co.uk/itm/321037185762? ... 1439.l2649
Professional Smart Split Charge 70 Amp Kit
andycaca
Postby knighty1981 » Tue Dec 25, 2012 2:31 am
redvendave wrote:a basic relay isnt a good idea , they burn out easily , i tried this route 100 amp relay ,100amp maxi fuses , relay lasted our 2weeks holiday ok when we next went away following weekend it just died .haveing looked into further its reckoned its relay chatter , as the relay is on and of all the time you stop and start engine
that's nothing compared to all the other relays in the van... lights, horn, heater, starter, et. etc.etc..
sounds like you were just unlucky... I've done it that way loads of times and never had a problem :-)
knighty1981
Postby mjsroofing » Tue Dec 25, 2012 8:37 pm
I can second this I have done a few set ups with standard and smart relays, all around 70-80amp.
Never had a problem , but I was told that it is important that u have the live feed in the right side same with the trigger live too.
But yeah wiper relays, indicators etc they are turning on and off all the time, heater plug relay etc etc.
Just make sure u have a good quality relay not a cheap one.
mjsroofing
