A bit more done, just laying out the van and cutting profiles and templates to transfer to a vaneered panel. Thing is a 1440 x 1200 x 15mm ply vaneered both sides panel is over £100 shocking.
The same sized panel in a chip board format is cheaper. There cannot be alot of difference in weight, i guess the ply is stronger ?
I thought this would be the easy bit !
