Mk6 underfloor water tank?
Postby firstimer » Sat Dec 22, 2012 9:58 pm
I have a home converted 2004 SWB camper van, mods carried out by previous owner. The interior is quite well converted, but the cold water supply relies on a small plastic container under the sink. I was thinking of fitting a larger underfloor tank; I've seen one advertised (but I can't find the ad now) and was wondering if anybody had an underfloor tank.
If so,
where did you fit it?
Was it difficult to fit?
Who supplied it and how much did it cost?
Any suggestions gratefully received.
firstimer
Re: Mk6 underfloor water tank?
Postby bigjohnthomas » Sat Dec 22, 2012 10:09 pm
under the back behind the axle
easy enough
heatons engineering 20 quid a sheet of thinner stainless and a packet of fags :D
bigjohnthomas
Postby pepper » Sun Dec 23, 2012 12:44 am
Or check out CAK at Kenilworth, they'd have a tank that would fit the bill.
http://www.caktanks.co.uk/
pepper
Postby whitemice » Sun Dec 23, 2012 1:36 am
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby AK » Sun Dec 23, 2012 5:33 pm
I have a 70l one on my mk7 just behnd the drivers seat area, under the van, I used some long threaded bars which wnet through the pre drilled holes in the chassis rails and made up some brackets to hand the tank from, then used 2 more long threaded bars under the tank to hold it in place
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
Postby firstimer » Sun Dec 23, 2012 5:58 pm
Thanks to all who have replied. I'll have a look underneath when it stops raining!
firstimer
Postby AeroNautiCal » Fri Dec 28, 2012 2:31 am
Don't forget to insulate the tank and pipes.
AeroNautiCal
Postby paulrichardson » Sun Dec 30, 2012 6:58 pm
AK wrote:I have a 70l one on my mk7 just behnd the drivers seat area, under the van, I used some long threaded bars which wnet through the pre drilled holes in the chassis rails and made up some brackets to hand the tank from, then used 2 more long threaded bars under the tank to hold it in place
Hi AK,
I'm going to fit a 70l tank under my MK7.
I'm looking at the the Fiamma one:-
http://www.ebay.co.uk/itm/CARAVAN-CAMPE ... 3f0e77041c
Is this the one you have?
I would love to see a photo of your installation, I've looked under my van and I can't figure out which pre drilled holes you used.
Regards,
Paul
paulrichardson
Postby whitemice » Sun Dec 30, 2012 7:04 pm
whitemice
Postby AK » Mon Dec 31, 2012 4:03 pm
Yes thats the one I have, think I paid £50ish for it from ebay. then I have a 30psi water pump mounted under the sink will pulls it up
Andrew
AK
Postby paulrichardson » Mon Dec 31, 2012 5:30 pm
whitemice wrote:better ebay price here,
http://compare.ebay.co.uk/like/13078916 ... pla&crdt=0
Thanks Whitemice,
I'll get one from there I think.
Regards,
Paul
paulrichardson
Postby paulrichardson » Mon Dec 31, 2012 5:32 pm
AK wrote:Yes thats the one I have, think I paid £50ish for it from ebay. then I have a 30psi water pump mounted under the sink will pulls it up
Hi AK,
That's exactly what I want to do.
If I ask REALLY nicely, :D could you take a photo of your tank installation for me.
Regards,
Paul
paulrichardson
Postby AK » Mon Dec 31, 2012 5:43 pm
I'll see what I can do tomorrow for you, but don't hold your breath as I might not be in any fit state to do anything tomorrow.
Won't be able to show the pump etc, as its in a closed cupboard, but i'll try to get pics of how the tank is hung
Andrew
AK
Postby paulrichardson » Mon Dec 31, 2012 6:00 pm
AK wrote:Won't be able to show the pump etc, as its in a closed cupboard, but i'll try to get pics of how the tank is hung
Hi AK,
Pictures of how the Tank is hung would be PERFECT, please don't worry about the pump pictures, but I'd be interested to learn what pump you went for.
Sounds like you are planning to celebrate the New Year, have a great night.
Hope to hear from you next year.
Regards,
Paul;
paulrichardson
Postby duvet » Mon Dec 31, 2012 6:46 pm
my old caravan just had a whale submersible pump running through a hole cut in the top of its onboard watertank.
cost about £12
ex-network rail 2007 mk7 100 LWB 350 8 seat.
buses stop at bus stations, trains stop at train stations....... on my desk i've got a workstation
duvet
