Hi all
A kind soul gave me a pro user inv800 800watt inverter today as thanks for helping them out.
My van is mk4 150lwb with twin battery trays. My leisure batt is on the nearside and is a Lucas 110amp deep cycle.
Where is the best place to mount my inverter? I would like it as close to the leisure batt as possible to minimise powerloss.
At first I thought about in engine bay with 240v cable through firewall plug into cab. Nice and clean. But - potentially damp and moist - and on the flip side - hot from the engine. Thoughts on this?
2nd is under the glove compartment, upside down mounted to the plastic. Should I be mounting it to a metal plate first and then to the plastic? Also, the cables for this thing are hefty, similar thickness to jump cables - what's the best way through the firewall with cables this thick?
Ok so now lets assume its mounted...
Can I hook the inverter to the the vans ring main?
To do this, I am initially thinking to cut the cable after fuse box and attach a plug on the cable out of fuse box and a socket on the ring main cable. An extension cable will come from inverter with another socket on, then to choose power source I change plug to either socket. Is this feasible? Any safety aspects I should take into account?
Many thanks.
Scott
