What is this wire (Split charge)
Postby suffolkboi » Mon Apr 01, 2013 7:10 pm
Is the blue wire for a charging light?
Comes from the back of the van and into the engine bay - then goes off to the split relay. Brown and yellow go to the leisure battery.
Mk5 Camper build - Work in progress
viewtopic.php?f=58&t=104595
suffolkboi
Re: What is this wire (Split charge)
Postby suffolkboi » Tue Apr 02, 2013 10:41 am
anyone..?
suffolkboi
Postby captain hook » Tue Apr 02, 2013 12:11 pm
The only person to know would be the person that fitted that wire.
It's not standard from Ford :wink:
captain hook
Postby suffolkboi » Tue Apr 02, 2013 12:24 pm
Yeah i know its not standard. But there is some very knowledgeable people on here who surely will know..
Its only a simple power take off from the leisure battery - but the blue wire is connect to the Split Charge relay.
suffolkboi
Postby tonylem » Tue Apr 02, 2013 4:03 pm
Power for a fridge perhaps, or other high drain appliance, so the power is only on when engine running.
2008 Mk7 MWB 140 T280 High Roof
tonylem
Postby barabas » Tue Apr 02, 2013 6:54 pm
tonylem wrote:Power for a fridge perhaps, or other high drain appliance, so the power is only on when engine running.
Thats what I'd guess too, put a meter on it and if nothing then start the engine and try again?
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby suffolkboi » Tue Apr 02, 2013 10:20 pm
Yes i will be getting the meter on it. How will i know if thats not just a charging indicator as oppose to high driain feed?
suffolkboi
Postby tonylem » Wed Apr 03, 2013 7:31 am
You may not be able to, it may have had some extra voltage sensing circuitry on the end, or it may simply have operated a relay. Without knowing what was plugged into it, you can only guess.
Get a multimeter on them, and see what happens with engine off/running.
tonylem
Postby AlanN » Wed Apr 03, 2013 10:58 pm
Most leisure split charge relays have the fridge power too, cools fridge down ready for when you change to gas or hook-up :wink:
