1988 Autosleeper Flair - MK3 Popular 100 base
Fridge operates on 12 and 220 volt yet not on gas.
Habitation check suggested failed electronic igniter.
Have found all four connections to igniter on fridge top to be severely corroded at connection to mini-spade female terminations.
So bad that they all broke away on lightest touch, leaving females engaged/stuck on module male spades. Whitish residue corrosion.
No problem re-terminating three wires from the neon power switch to reconnect to igniter.
However, thin wire to the igniter was to an exact length, which leaves little or no room for new termination and reach igniter module.
This is a very very thin stiff wire, not multi-strand as the other normal 12v cables, it is not sheathed against heat.
What type of wire is this, going down to the pilot light ,and can I extend it with some multi-strand normal wire to lengthen it a few inches
without compromising operation?
Any info gratefully awaited.
