Travel home walls
Travel home walls
Postby bov783 » Thu Dec 19, 2013 9:32 pm
Hi all
My walls in me 1978 travelhome have become damp and de bonded. In a trip back from Inverness when we went over the forth road bridge the walls were visibly ballooning out !!
My point is can anyone recommend a glue to stick 6mm ply to the blue styrene insulation ?
The insulation is stuck solid to the alloy skin but the inner wall has gone.
I think 6mm ply will do for the wall as I can get it from work.
Regards
Phil
bov783
Re: Travel home walls
Postby myceliumu3 » Wed Jan 01, 2014 11:43 pm
Hi Phil,
Just been looking on utube under reparing major water damage in a motorhome, well worth watching over 30 mins long but good with bonding and parts / interior panels. :) Gentleman concerned used a company called oleary to get parts http://www.olearymotorhomes.co.uk I hope the address is ok or google it. Adhesive he used was oleary FC40 bonding glue.
Watch the video I am sure it will help you.
Hope this helps and please post your progress with maybe a How To repair on the forum. :wink:
Best of luck,
Regards
Charles
I only go to the garage for mot
myceliumu3
Postby Kedishen » Sat Jan 25, 2014 12:51 am
Expanding wood glue does a great job too. Its not a sealant though so if you have a leak, then maybe something like sikaflex 512 would be suitable - only issue is it takes a long time to dry in the UK.
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby Jambofive » Sat Jan 25, 2014 7:11 pm
hey phil how did your van feel on the bridge went over it few months back in my mk2 motorhome was quite windy and felt like it was going to blow over lol couldnt believe the difference between it and my hitop as for your walls i would use sikaflex but would have a heater in it help it dry
81 MK2 motorhome
93 county 4x4
98 hi cube jumbo smiley td
00 flat bed smiley td
90 mk4 esc rs turbo
91 mk5 esc rs turbo
00 Mondeo st24 estate td
02 fiesta XRV td
Jambofive
Postby matt86_wd2 » Sun Jan 26, 2014 11:16 am
talking about winds i was coming up the a34 from southampton to oxford yesterday late afternoon / early eve and that was a bit of a white knuckle ride some moments , the van is a hightop and was getting blown alot more than normal so much i slowed down to 45/50 still felt i was going to tip over or even change lanes ... what didnt help when you was on a brow of a hill and a big gust of wind blew across ! !st time driven in higher winds with it and its certainly not nice .
matt86_wd2
Postby Jambofive » Sun Jan 26, 2014 11:42 am
Yes can be very scary I drive a hi top most days and never bothers me but motorhome totally different even if a hgv passes you fast it will suck you in then push u away can be nerve racking if your not expecting it I though there was something wrong with my old camper the way it was blowing about on the first journey home but soon came to realise that it's one off the things you have to live with when running a classic lol
81 MK2 motorhome
93 county 4x4
90 mk4 esc rs turbo
91 mk5 esc rs turbo
02 fiesta XRV td
Jambofive
Postby pelmetman » Sat Jun 07, 2014 8:14 pm
Jambofive wrote:Yes can be very scary I drive a hi top most days and never bothers me but motorhome totally different even if a hgv passes you fast it will suck you in then push u away can be nerve racking if your not expecting it I though there was something wrong with my old camper the way it was blowing about on the first journey home but soon came to realise that it's one off the things you have to live with when running a classic lol
Have you thought about air bags?............I had them fitted a few years back to my 1990 Travelhome.............they made a big difference to the handling.
Fanny a 99 LWB Semi high roof MK 5......Essex V6 auto..... Sold
Horace a 90 SWB Ford Travelhome MK 3....2.5 diesel manual
pelmetman
Postby Jambofive » Tue Jun 17, 2014 7:07 pm
No hadn't thought of that air bags all round front and rear am def thinking bout a set for my county
81 MK2 motorhome
93 county 4x4
90 mk4 esc rs turbo
91 mk5 esc rs turbo
02 fiesta XRV td
Jambofive
