help needed heater for a camper
Postby zetor4321 » Wed Jan 22, 2014 10:40 pm
Hi all, ive got a swb mk 5 van and i occasionally work away for 1 or 2 nights
I sleep in the van to give security to my equipment.
i want to fit a small gas fired heater which is suitable for use in a van.
i was thinking of something like what is fitted in caravans
i want to keep it as small and compact as possible
any suggestions will be appreciated
any pics and links would be a great help
thanks in advance
Dave
zetor4321
Re: help needed heater for a camper
Postby squiddley21 » Fri Jan 24, 2014 9:07 pm
I fitted a webasto heater in my LWB Connect, small and compact runs off the vans fuel tank.
like yourself i spend a couple of nights away in my van,and have to say it was a good investment.
squiddley21
Postby Jambofive » Fri Jan 24, 2014 10:32 pm
i have a mini super ser in mine like a little two bar gas heater very small and compact u just secure it to side of van with good little heat enough to heat back of van ill stick a pic up off it
81 MK2 motorhome
93 county 4x4
98 hi cube jumbo smiley td
00 flat bed smiley td
90 mk4 esc rs turbo
91 mk5 esc rs turbo
00 Mondeo st24 estate td
02 fiesta XRV td
Jambofive
Postby zetor4321 » Sat Jan 25, 2014 12:10 am
How much was the webasto heater and was it difficult to fit??
could it run from a separate fuel tank?
i did think of the super ser type heaters but thought it would give off too many fumes?
is yours vented outside ?
i have an old calor gas type mobile heater but as i say i was worried about fumes and condensation
a picture would be helpful of both types
Dave
zetor4321
Postby robbie.cee » Sat Jan 25, 2014 12:25 am
If you have the luxury of hook up, places lile qvs sell these heater tubes that range in length frim a foot to about 8 foot.
The 3 or 4 foot ones are only 175w, the 8 foot ones only use about 400w...
Fek all if on hook up...
Fit under seats etc..
Just thought this may be an alternative
Hope this helps (Someone)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Kedishen » Sat Jan 25, 2014 12:45 am
I use something similar to this:
http://www.ebay.co.uk/itm/motorcaravan- ... 1329290652
Mine came out of a 1970's horsebox. Doesn't require a flue, just make sure your have a carbon monoxide detector :)
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby zetor4321 » Sat Jan 25, 2014 11:14 am
Unfortunately i don't have access to mains power as i mainly park up in fields etc
i do have a similar heater to the one you linked to but was worried about fumes
has anybody fitted a heater from a caravan the carver type one
they are vented under the caravan so i assume are safe to use all night?
dave
zetor4321
Postby Jambofive » Sat Jan 25, 2014 6:08 pm
I was also worried about fumes as kids travel with us so fitted a co2 / smoke alarm just incase but i tested it on a trip first before I took kids away run fine no fumes but my motorhome is quite well ventilated not sure I would advise running while sleeping in the back of a van just incase if u want something to run all night wabasto is the way to go just more expensive a bit more work to install
This is mine
81 MK2 motorhome
93 county 4x4
90 mk4 esc rs turbo
91 mk5 esc rs turbo
02 fiesta XRV td
Jambofive
Postby ake » Sat Jan 25, 2014 8:27 pm
robbie.cee wrote:If you have the luxury of hook up, places lile qvs sell these heater tubes that range in length frim a foot to about 8 foot.
Usually 60 watts per foot ;)
Postby matt86_wd2 » Sun Jan 26, 2014 10:47 am
at the moment i have this on ebay but you have to hurry as ends later
http://www.ebay.co.uk/itm/201023066266? ... 1555.l2649
matt
matt86_wd2
Postby zetor4321 » Sun Jan 26, 2014 4:35 pm
Thanks for the link but its more than i want to spend
As i will only use it half a dozen times a year
zetor4321
Postby matt86_wd2 » Sun Jan 26, 2014 7:22 pm
i only started the bidding at £80 and look how its gone up !
matt86_wd2
Postby Kedishen » Sun Jan 26, 2014 8:01 pm
Woosh, i got one of those. Thinking about selling now!
Kedishen
Postby matt86_wd2 » Sun Jan 26, 2014 8:20 pm
that one is brand new though so its unused ...
they make good money as you can see
matt
matt86_wd2
Postby hornhead » Sun Jan 26, 2014 8:22 pm
Truna E2400 imho 8)
quietest...if you have gas already, no contest...low firing/no amps cos no glow plugs...
had 2 years so far so good...
old propex way over priced as no spares...i checked :shock:
shop around for E2400 £, varies wildly
hornhead
