Log book change - Do i need to box in gas bottle?
Postby suffolkboi » Thu Feb 06, 2014 2:17 pm
Can someone confirm if the gas bottle must be ina air tight box for the Log Book change?
From what ive read it just need to be secured. Would like to know before i send all my stuff off though..
Mk5 Camper build - Work in progress
viewtopic.php?f=58&t=104595
suffolkboi
Re: Log book change - Do i need to box in gas bottle?
Postby john kyte » Thu Feb 06, 2014 2:48 pm
I dont know answer,,,but on my 89 camper,,still an ambulance on v5 ,but insured as camper I have a chest of drawers
So,i removed two drawers ,cut a hole in floor below,then dropped the gas bottle into home made metal cage below floor--then put the two drawers back in
Result----saves space and the gas is outside[under] the van ---must be safer too
john kyte
Postby FredTransit » Thu Feb 06, 2014 5:11 pm
this sounds more like a question for the insurance than the DVLA. On the subject of your V5, the post office now do this at the counter. When I asked for what proof was needed I was told none! You can only change the tax class when you renew your tax.
FredTransit
Mk2 Trannyist
Postby suffolkboi » Thu Feb 06, 2014 5:47 pm
Im talking about changing the description to 'Motor Caravan'. I dont want to send all my photos etc off, and have the DVLA tell me the Gas bottle needs to be boxed.
suffolkboi
Postby FredTransit » Thu Feb 06, 2014 7:29 pm
really? This is body type then? Not taxation class? I shall ask the PO if they are doing this too, as they have taken a lot over from the DVLA after the local office closures. Cant see how the gas bottle is fitted makes any difference as the cooker can be electric.
FredTransit
Mk2 Trannyist
Postby TIMO » Thu Feb 06, 2014 9:08 pm
Im pretty sure you need any bottles boxed in,,, they also require a vent to the outside in case of leaks,,, not sure if its covered here but deffo a useful bit of info :arrow: :arrow: :arrow: viewtopic.php?f=58&t=65473
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby suffolkboi » Thu Feb 06, 2014 10:05 pm
It appears not. I got this email from the DVLA
Thank you for your email received on 6/2/14. Your email reference number is 1775074.
The vehicle is required to display the following characteristics in order to meet the interpretation of “Motor Caravan”:-
Seats and a Table
integral part of vehicle living accommodation area, (mounted independently of other items)
table capable of being mounted directly to the vehicle floor and/or side wall
table mounting arrangement secured is a permanent feature, (bolted, riveted, screwed or welded) although table may be detachable
seats secured directly to the vehicle floor and/or side-wall
seats secured as a permanent feature, (bolted, riveted, screwed or welded)
Sleeping Accommodation
either beds or beds converted from seats (to form a mattress)
secured as a permanent feature, (with base structures bolted, riveted, screwed or welded)
secured directly to the vehicle floor and/or side wall, (unless provision over driver’s cab compartment)
Cooking Facilities
integral part of vehicle living accommodation, (mounted independently of other items)
secured as a permanent feature, (bodied, riveted, screwed or welded)
minimum of two ring cooking facility or microwave equipped in either case with fuel/power source
Storage Facilities
cupboard / Locker
integral part of vehicle living accommodation (mounted independently of other items, unless incorporated below seat/sleeping accommodation or the cooker)
secured as a permanent feature (bolted, riveted, screwed or welded)
secured directly to the vehicle floor and/or side wall (unless provision over driver’s cab compartment)
suffolkboi
Postby TIMO » Thu Feb 06, 2014 10:53 pm
Hmmm :| but as you would need a gas safe certificate for the build,, an enclosed locker with an external vent would be a gas safe requirement anyway,, so i would personally do it for my own well being anyway :D ,
TIMO
Postby matt86_wd2 » Thu Feb 06, 2014 11:25 pm
were does it say you need a gas safe cert ?
I spoke to my dads mate who is gas safe registered and he said all he would do is do a gas leak test and make sure gas drop out vents by the joints .
As far i can see dvla or my insurance dont require a cert for the gas
matt
matt86_wd2
Postby TIMO » Fri Feb 07, 2014 12:00 am
matt86_wd2 wrote:were does it say you need a gas safe cert ?
matt
F,,k knows,,, but its in the beaurocracy somewhere believe me,,, apart from that,, wouldn t it be prudent to have a gas bottle inside a sealed compartment if inside the van,, with an external vent ,,? ,, all battery boxes have to have them as they produce gasses,, its a simple self preservation excersise to do it as standard dont you think ? Ever seen a propane explosion ?
TIMO
Postby matt86_wd2 » Fri Feb 07, 2014 12:11 am
ive seen a acetylene explosion before in a barn ... no pretty at all . This is why i have this ....
and still have drop out vents under hob and sink unit .
matt
matt86_wd2
Postby matt86_wd2 » Fri Feb 07, 2014 12:12 am
matt
Ahh i better vent my battery box then ? a small pipe going through floor will do i guess ?
matt
matt86_wd2
Postby TIMO » Fri Feb 07, 2014 12:16 am
:D exactly mate ,, failing to self preserve can cause death :shock: :lol: if you carry the bottle in the van youre legally required to have propane stickers on the van too . :roll:
TIMO
Postby TIMO » Fri Feb 07, 2014 12:18 am
is yours mk6,, dont the battery have a vented pipe going through the floor ? Or you got a seperate liesure battery box? if so i,d vent it out if its inside the van
TIMO
Postby matt86_wd2 » Fri Feb 07, 2014 7:44 am
Yes a mk6 mate , was talking about liesure battery in the back of van , not quite in middle behind drivers seat a foot from the wall
Matt
matt86_wd2
