Mk6 steering wheel
Mk6 steering wheel
Postby archerswb280 » Sun May 18, 2014 10:32 am
I'm thinking of changing my mk6 steering wheel, does anybody know if a mk3 focus (4 spoke) wheel's airbag has the same connection as the mk6 transit? It looks similar to the mk7 transits wheel. I know there will be mods to do to get it fitted just need to know if I'd need to do anything the the wiring if possible.
Thanks in advance people!!
archerswb280
Re: Mk6 steering wheel
Postby blue estate » Sun May 18, 2014 12:06 pm
No wheel is a direct replacement for mk 6 :( :wink:
But a focus or Cmax 4 spoke will fit a mk7 (I know mine is one ) :wink:
blue estate
Postby tricky68 » Tue May 20, 2014 8:14 pm
Hi
Would a mk 3 Mondeo steering wheel fit a mk7 transit?
tricky68
Postby ake » Sat May 31, 2014 9:03 am
tricky68 wrote:Hi
Yeah, pretty sure that's been done
Postby xxbigunxx » Thu Jun 05, 2014 6:25 pm
No mk3 mondeo doesn't fit it is the mk2 mondeo that fits also if its a deisel the clocks fit aswell only the glow plug light is wrong place with empty petrol light. I took apart and cut with a scalpel and glued into the right place.
xxbigunxx
Postby jay » Thu Jun 05, 2014 11:01 pm
MK3 Mondeo wheel only fits 2 ways or 3 if a bodger..
1st way is cut a mk6 transit wheel centre out and drill to act as a boss for a mk3 mondeo wheel need a longer centre bolt to make this all fit..
2nd way is drill out the spline on mk6 with hole saw and do the same on mondeo wheel then add a spline to each part then bolt the lot to the transit using a bigger washer or u can get them welded together..
3rd way the bodgers way bu has worked before..is just file the mondeo wheel to fit and add a few splines so it grips then loctite it together on transit..
mk1 connect tourneo
jay
