Split Charge Relay via Can Bus?
Postby Brizzler » Tue Jul 15, 2014 9:38 am
Hi,
Picked up my camper from the garage last week and the mechanic was quite critical of the leisure battery split charge relay being wired directly to the start battery.
He reckoned it should go via the Can Bus to avoid any problems.
Is that correct (I've not had any problems so far with the current set up)??
EDIT:
The relay kit (bought from a vehicle electrical suppliers) uses a solenoid which he also slated!
Brizzler
Re: Split Charge Relay via Can Bus?
Postby ake » Tue Jul 15, 2014 5:55 pm
It should be okay, if it is done as per the instructions in the Ford BEMM manual, which is available on etis.ford.com
Trying to tie it in to the can bus could cause much more problems!!!
Postby Brizzler » Wed Jul 16, 2014 7:34 am
ake wrote:It should be okay, if it is done as per the instructions in the Ford BEMM manual, which is available on etis.ford.com
Thanks Ake.
The guy who wired it up is pretty knowledgeable having converted many vans and he was happy.
Brizzler
Postby ake » Wed Jul 16, 2014 5:53 pm
Thanks Ake.
All sounds good then
