Hello chaps
Got a few off the wall questions for you.
Firstly, to set the scene, I have a year 2000 LWB 2.5D hi top camper conversion, with lights, TV etc running off a couple of leisure batteries at the back. In the dashboard is the standard factory fit radio CD running off the starter batteries (yes there are two of these).
Meanwhile, I have an old (but good) JVC Head Unit and 12 disc autochanger which I would quite like to install in the back to run off the leisure battery.
Now I'm not much good with electrics but I do have a spare cigarette lighter socket in the back which is very handily located for the installation of the head unit and auto changer.
My question is simply this. How can I connect the head unit to the 12v supply that comes out of the cigarette lighter socket? I guess I could easily buy a cigarette lighter lead (say a phone charger), cut the phone connector off and connect the wire to the wire to the back of the head unit to give it power. But would this work? And I think there are TWO wires that come out of the socket - positive and negative. Which do I use? Or do I join them together? Or connect them to different terminals in the block at the back of the head unit? And what about Earth? I think the fact that it's an already functioning and professionally installed lighter socket means it is already earthed. Is that right?
I do realise this whole solution is a bit Heath Robinson and not really ideal. However, at the end of the day I guess it is a simple question:- how do I get the 12v power from a lighter socket into the back of a car radio?
Any advice gratefully appreciated.
Ian
