bigjohnthomas wrote:Just run a copper pipe underneath the van screesho bit of gaffer tape ,cable tie sorted
LPG is heavier than air so if it leaks a lot it won't be a problem as it goes down unless you are sat underneath the van having a fag
Hth
Dr allcock
bigjohnthomas wrote:Copper dosnt rust
g-man wrote:bigjohnthomas wrote:Copper dosnt rust
true......but can corrode
max.print wrote:g-man wrote:bigjohnthomas wrote:Copper dosnt rust
No different to having your brake pipes clipped to the chassis
