Battery wiring and fusing
Postby sand010 » Wed Nov 05, 2014 12:43 am
Hi guys got some questions about wiring a 12v battery bank in series...
Firstly, shoule i wire the batteries like in the image below. I have read that each battery should be individually fused.... the batteries are 110ah and the cable size is 25mm
[img][IMG]http://i36.photobucket.com/albums/e1/sandy_lewis2/batterywiringdiagram_zpse4c088a4.jpg[/img][/img]
Secondly am i right in thinking i connect the battery charger, shunt for the battery monitor and the DC DC charger to any terminal post or busbar?? providing its the correct polarity e.g. neg to neg and pos to pos.
thanks guys
sand010
Re: Battery wiring and fusing
Postby sand010 » Wed Nov 05, 2014 9:48 am
Sorry guys just seen my edit i meant in parallel not series. Thanks
sand010
Postby blizard » Thu Nov 06, 2014 11:25 pm
Hi,
Are your batteries exactly the same, if they are different they will eat eachother. The best one will offer itself to the worst one.
Best is to have batterys of the same batch.
The lenght of the wiring should also be equal to another
You can ty all the power supplies in one spot, ofcourse + with +, - with -. Electricity will follow the easiest way
The shunt should be mounted on the negative as near as possible to the battery, the supplied manual will tell you that also.
In your drawing you have an extra negative lead, in this setup the battery monitor won't work, the shunt must be in the neg. circuit
Transit MK3 1987
Chausson Motorhome
Engine 2.5TD of 2000 (last production year of the DI, I'm told)
Gearbox MT75
blizard
Postby sand010 » Fri Nov 07, 2014 12:14 am
Blizard,
yes they are all exactly the same battery so shouldn't have any problems there. i am going to ignore the fuses for each battery and just wire the same as you have in your diagram. will have a 100amp fuse going to and from the battery bank so should be more than safe.
The extra negative in my diagram do you mean the grounding point? or the negative busbar?
sand010
Postby blizard » Sat Nov 08, 2014 3:46 pm
In your negative lead you should mount the shunt, anyway it had to be done with mine:
http://www.victronenergy.com/upload/documents/Quick-install-guide-BMV602-website-EN.pdf
Victron suggests also a fuse in the positive lead
Transit MK3 1987
Chausson Motorhome
Gearbox MT75
blizard
