PAINT
PAINT
Postby mtbcol » Fri May 15, 2015 3:43 pm
Hello all
Does anyone know if Hamerite smooth brush paint will "react" with the original paint on the outside of my van? (I have found a pot in the garage and need to do some quick exterior "tidying up" before we go on holiday). If not any other brush pain I can use and buy off the shelf?
Cheers
Colin. :D
mtbcol
Re: PAINT
Postby loot » Fri May 15, 2015 4:09 pm
It won't react but it tends to give a skin over the original paint if that makes sense, i use it and it's good for a while :-)
Ids map here
loot
Re: PAINT
Postby mtbcol » Fri May 15, 2015 4:18 pm
Thanks loot, as i've got some i'll use it. It will do as a temporary fix!
Cheers
Colin. :D
mtbcol
Re: PAINT
Postby fidodido37 » Sat May 16, 2015 2:39 pm
If you use it make sure that you sand the rough bit off and use it as a primer for the aerosol..
fidodido37
