Distributor differences
Postby danielk5787 » Sun Jul 12, 2015 1:56 pm
Just a quickie, are these 2 the same? The one fitted has an extra 2 wires attached and an extra vac line. Ive bought the new one off ebay and was described as "all pinto 1.6 and 2.0 points distributor"
4 transits, 2 years, still own 2.
danielk5787
Re: Distributor differences
Postby danielk5787 » Sun Jul 12, 2015 1:59 pm
danielk5787
Postby danielk5787 » Sun Jul 12, 2015 2:01 pm
danielk5787
Postby Terry » Tue Jul 14, 2015 7:22 pm
Hi
I would say yes they are the same.
They are both 'Motorcraft' by the look of them. The same rotor arm should fit both.
Look up 'Hall Effect'............... will help with the different appearance.
As to wiring... sorry it was long ago (and in a galaxy far far away) too far to remember.
H.T.H.
Terry
Pallet Puller
Terry
Postby ake » Wed Jul 15, 2015 7:12 am
The top picture is a points distributor for conventional ignition
The lower picture is a Hall effect distributor for electronic ignition, not interchangeable as far as I am aware.
Postby loot » Fri Jul 17, 2015 9:26 am
Been a long time since i saw a points distributor 8)
I used to change the fiesta distributor to electronic, why couldn't you do the same? Points ones can require new points quite regularly as i found :?
Even better, you can take a mk4 later escort complete dis system and fit it, it is self contained.
You'll need to check compatability
Ids map here
loot
Postby andypdq » Fri Jul 17, 2015 11:32 am
Don't see why you can't interchange, Hall effect is preferable to mechanical points as long as you can get the simple electronic module wiring sorted. Don't know too much about the Pinto, but swapping gave a noticeable power/economy benefit on the Rover V8. :D
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby bortaf » Sun Jul 19, 2015 8:42 pm
Thye are both bosch dizzys, as said 1 is points, 1 is electric but the leccy one wont run without the ign amp modual, if you find a modual here's the wiring.
it will fit the only differance will be the timing, trust me there a LOADS of differant advance curves dependant on comp ratio, carb, fitment ect ect but you will not notice the differance on the road only a rolling road would show up the differances
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby MinorMatt » Mon Jul 20, 2015 2:16 pm
If you need an amplifier shout quickly. I have one on a shell I'm about to scrap
