Lock and unlock rear doors without remote or key?
Postby stezie » Thu Jul 23, 2015 1:36 am
For my mk 6 converted camper I'd like a way to open the locks on the rear door without fumbling about for the remote. Is there a wire I could put a switch on that will pop them open for me?
stezie
Re: Lock and unlock rear doors without remote or key?
Postby ergs » Thu Jul 23, 2015 10:31 pm
am I missing something here? if you're inside the van you can open it with the handle, so are you looking for a switch (presumably in the cab) to unlock the back door, but if you're in the cab then the central locking is unlocked and the door will open, no?
ergs
Postby stezie » Fri Jul 24, 2015 1:05 am
yeah while in the back i want to be able unlock the side door, with a switch. using the door handles in the cab area wont work all the time as i have a bunk across the front seats so cant reach over whoever is sleeping there
stezie
Postby ake » Sun Jul 26, 2015 11:25 am
stezie wrote:yeah while in the back i want to be able unlock the side door, with a switch. using the door handles in the cab area wont work all the time as i have a bunk across the front seats so cant reach over whoever is sleeping there
There should be a twist knob on the rear edge of the side door to lock/unlock the door
Postby stezie » Mon Jul 27, 2015 2:01 am
My side door does not have any knobs unfortunately
stezie
Postby ake » Tue Jul 28, 2015 8:35 pm
stezie wrote:My side door does not have any knobs unfortunately
Get one from a scrappiest and fit it!
The door will have the hole for it already
Postby darkbluevanman » Thu Jul 30, 2015 8:48 pm
5 quid solenoid (like for car C/locking and a double pole double throw centre off switch.... will allow you to lock/unlock from the inside :)
darkbluevanman
