Help installing a leisure battery.
Postby GnarlyDon » Mon Apr 25, 2016 10:01 pm
Hi all.
I know that this has most probably been asked a fair few times but here goes. Ive recently brought a mk7 transit 115 trend and im looking to fit a leisure battery and need to know a few things. 1. Can i install the leisure battery under the drivers seat next to the main battery. If so what would i need to make it secure. 2. What would i need to buy to install it myself. I have seen a few leisure battery split charge kits on amazon for around £40, will this be all i need? All i want to run is a double 13amp socket and a circuit of 4 12v led spotlights. I need to know what id need for this and the easiest way of going about the install as im a bit of a novice when it comes to this kind of thing but i want to give it a try. Cheers in advance for your help guys.
GnarlyDon
Re: Help installing a leisure battery.
Postby ake » Sat Apr 30, 2016 6:18 pm
The genuine set up is as good as any
viewtopic.php?f=18&t=89599
Postby GnarlyDon » Tue May 03, 2016 6:35 pm
Cheers man.
GnarlyDon
Postby mjsroofing » Fri May 27, 2016 7:20 am
I use a intelligent split charger, just three wires, Earth, live in and live out, it automatically opens when voltage reaches 14volts.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby Wongo » Tue May 31, 2016 7:04 pm
12volt Planet do a complete kit, use the best intelligent relay as stated, two 13amp sockets and the required inverter will need a lot of power, leisure batteries will struggle, what's the need here?
Wongo
Postby mjsroofing » Tue May 31, 2016 9:24 pm
Depends what you powering, I run several sockets off my inverter , well you can have as many sockets as you want as long as they are not all in use.
Tell us what you want to use the sockets for.
mjsroofing
