Van: 2011 Ford Transit RWB, Reg height.
So I got 10m x 1m of this - http://www.kiravans.co.uk/lining/carpet ... mpervan-...
1. But now I am wrestling with what to add to that? Should I put that on for the big flat pieces and then add fibreglass insulation over it? (The safe kind obviously.) I live in Europe and it will be mostly for 3 season use, although it would be nice for it to be comfortable for winter use as well. Right now I am leaning towards just the 6mm closed cell foam and plywood to see how comfortable it is or not.
2. As for the floor I am planning on the 6mm closed cell foam in between the ribs, then plywood then vinyl. Another question... should I add something more to that?
3. Don't think I am going to a fan as the ribs in the ceiling will make it a major pain in the ass to deal with. There is only a 7 inch wide strip down the center of the van for installment of such. So I am thinking I will roll with just vents. Just regular floor vents? Location? One up high and one down low? And right on the outer/inner skin? (The thinnest part?)
4. Also, thoughts on vapor barriers? I'm leaning against it.
Thanks bros!
Bam
