vanvliet wrote:For info :
The drivers seat swivel will work absolutely fine if you have a fixed double passenger seat. The swivel currently on sale from Kiravan is compatible with Transit Custom vans from 2013+ and there is handbrake modification kit with it.
There is further information regarding the handbrake modification kit on their product page if required: http://www.kiravans.co.uk/scopema-rib-c ... swivel-rib
vanvliet wrote:vanvliet wrote:For info :
This info given to me was incorrect I asked them to clarify and they now say:
''We sell single drivers and passengers swivels for the ford transit custom 2013+.
We don't have any plans yet to make a double swivel for the 2013+ model.
The drivers single seat can't swivel alongside a fixed double passenger seat, you need to have a double swivel also. You need to be able to rotate both - first the double seat half way and then turn the drivers seat for it to work.
If you have a single drivers and a single passengers they can both turn ok though, yes!
We don't do fitting at Kiravans, you need to go to your local converter.''
Mk2harrier wrote:i have converted my double seat to swivel, it will turn independently as the drivers seat is fixed. Kiravans said they had made two attempts at making one but decided it was too difficult and shelved the idea. mine works perfectly and is absolutely solid with 4 locking points, only down side is that the original base covers no longer fit but i will be boxing it in using the same wood i have used for the units. if anyone wants any more info just get in touch.
