ELECTRIC HOOK UP POINT.
Postby mtbcol » Thu Dec 29, 2016 9:11 pm
Hello all
Is there a recommended place for fitting a surface mounted 240V electric hook up point? (Mk7, mwb, mh) I didn't want to screw it to a panel as I think that may be too flexible?
Any ideas or pictures of where others have put theirs wold be useful.
Thank you.
Colin. :)
mtbcol
Re: ELECTRIC HOOK UP POINT.
Postby Beaker » Thu Dec 29, 2016 10:23 pm
The favoured location these days seems to be under the bonnet. Good secure location, and saves cutting holes in the side of your van. Stealthy too.
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
Beaker
Postby mtbcol » Fri Dec 30, 2016 12:24 pm
That sounds good. Could I still close the bonnet fully though? Don't want too much water in there when its raining hard!
Am I being too picky?
mtbcol
Postby ake » Sat Dec 31, 2016 9:21 am
mtbcol wrote:That sounds good. Could I still close the bonnet fully though? Don't want too much water in there when its raining hard!
Yes
And
Yes !
Another popular place is inside the van, accessed through the drivers door
Then you don't forget to unplug before you drive away!
Postby bigjohnthomas » Sat Dec 31, 2016 11:28 am
Those blue plugs are rubbish I've melted loads of them
Most rubust way I've found is a normal domestic plug under the passenger seat going up to over the cab fuse box
Never melted one yet well,,, I say never I melted one plug but the neutral wire came a bit loose
You need to check them every month when you valet as many arses as I doImage
bigjohnthomas
Postby mtbcol » Sat Dec 31, 2016 9:04 pm
Yes
And
Yes !
Haha! It's my van ocd :lol:
I think through the drivers door is a good option for me, as otherwise I am quite likely to drive off with it still connected, with campsite electrics in tow :oops:
Thank's ake.
bigjohnthomas wrote:Those blue plugs are rubbish I've melted loads of them
Bugger! just spent a tenner on a blue plug :( Oh well, I'll go with the 13 amp plug top when iv'e melted the blue one! :roll:
Thank's BJT
HAPPY NEW YEAR TO YOU ALL! :D
Colin.
mtbcol
Postby ake » Mon Jan 02, 2017 4:12 pm
Yes
And
Yes !
Thank's ake.
Thank's BJT
Colin.
Good quality blue plug, with good tight connections, and you shouldn't have any problems
Postby mtbcol » Mon Jan 02, 2017 7:30 pm
Thanks' ake.
Colin.
mtbcol
Postby bigjohnthomas » Mon Jan 02, 2017 8:40 pm
Its the connections that cause the problems they get hot cool down loosen up a bit and if your not on the ball melt :P
but that's better than melting the socket in someones house that the other ends plugged into
Done that a few times over the years :oops:
I don't know why the most I can draw is about 9500watts with everything on :mrgreen:
bigjohnthomas
Postby robbie.cee » Mon Jan 02, 2017 8:53 pm
About 36amps them
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby bigjohnthomas » Mon Jan 02, 2017 8:55 pm
Probably should be wired in to the grid really
But I don't switch them all on at once
bigjohnthomas
Postby robbie.cee » Mon Jan 02, 2017 11:11 pm
No wonder you melted a 16amp plug unless wire was too thin and overheated pins. Need shower cable for 9.5kw!!
Had
MAKE IT FIT
robbie.cee
Postby bigjohnthomas » Tue Jan 03, 2017 9:31 am
Haven't used a blue plug for about 10 years there was one on the arsewash 1000 it was bloody rubbish
Melted a few normal plugs since though :P
I think some of its to do with the quality of sockets that I have to plug in to, poundland
3x heaters 2 x dryers all 2000watts + the other stuff (pump 500w, lights 120w and 2 electric tables prob about 200w between them ) but I only ever have 1 heater or dryer on at once so never pull more than about 2500w much more than that and peoples fuses start tripping at switch on and they don't know where the fusebox is
Tighten screw's in the plug every week and a new plug every couple of months sorts my end out
But there nothing I can do about the other end
bigjohnthomas
Postby hectors-tranny » Mon Jan 09, 2017 5:22 pm
I put my hookup point just inside the rear door, and just shut the door on the cable. I didn't want to cut the side of the vehicle, and a run from under the bonnet was a bit of a pain. I found that running the cable through the bottom door seal with the door closed was not a problem and rainwater can't travel upward through the gap. Little pressure on mains cable. (This for a Mk 8 though.) I imagine that no-one would recommend this, but works fine for me!
On my previous van I fixed the socket underneath the van with the cable running up through the floor. That was a real pain to hook up though.
hectors-tranny
Postby mtbcol » Mon Jan 09, 2017 10:34 pm
Hi hectors-tranny.
Brilliant! Thanks' for the idea and the photo.
Ours is a Mk7, but I can adopt the same principle. I was wondering what I was going to do about the small daylight gap at the bottom of the two rear doors when they were shut......that is where my hookup cable will now go! :D
I was thinking of the cable exiting from the drivers door so I didnt drive off with it still attached, but I think your idea is better. I can always hang a sign "unplug!" on the steering wheel :lol:
Just need to wait for the blue hook up plug to arrive now.
Thank's again.
Colin.
mtbcol
