Difficult to say really - it depends on what you intend to use as your insulating material. If you intend to use a loose fit insulation like Rockwool, recycled plastic bottle insulation or silver foil bubble wrap, they do very little to deaden sound - so you need more of your Dynamat type stuff. However if you plan on using self adhesive thermoliner, it has excellent acoustic deadening so you don't really need the Dynamat at all. This is how I have done it, the thermoliner makes a huge difference, and I did not install any Dynamat first. I can honestly say that on the motorway the van is no noisier than my Mondeo estate.
Doing the whole van is expensive overkill though - from what I can see you only need a piece in the middle of a panel - you don't need to cover all of it.
Like this:
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
