led lights
led lights
Postby jonnyboy1958 » Tue Mar 07, 2017 12:27 am
Does anyone know If I have to use a relay if using led lights in my camper conversion. I have not installed them yet as I am collecting all the parts I need then hibernate in the garage until I finish it lol! No, I have been buying parts when I can afford them and am close to starting the conversion but I read on another thread that a relay was used? Would this also be true about changing the cab courtesy lights?
Transit swb 2001 t260 Campervan fwd 2.0
jonnyboy1958
Re: led lights
Postby NickJ » Tue Mar 07, 2017 5:42 am
I've not heard about using relays for LED's I just have mine running from a fuse board to the battery.
Sent from my SM-N910F using Tapatalk
NickJ
Re: led lights
Postby jonnyboy1958 » Tue Mar 07, 2017 10:55 am
Thanks for your reply, I just thought I should check before using.
jonnyboy1958
Re: led lights
Postby NickJ » Tue Mar 07, 2017 11:36 am
I've read you can also run them without fuses but I like to have a fuse in there.
NickJ
Re: led lights
Postby jonnyboy1958 » Mon Mar 13, 2017 8:15 pm
Thanks for your replies, they are most helpful.
jonnyboy1958
Re: led lights
Postby dumper » Mon Mar 13, 2017 8:48 pm
Hi I have 6 led lights in my van for comeing upto 7 years now no relay just fused with no problem
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: led lights
Postby jonnyboy1958 » Thu Mar 16, 2017 2:01 pm
Thanks for that Dumper, I thought as much but got to check.
jonnyboy1958
