Floor thermal insulation.
Postby GBW » Fri Dec 29, 2017 11:12 am
Apart from the original plywood floor, there is none. Although the air temperature is comfortable, feet are COLD!
To install inside would mean a huge amount of dismantling and rebuilding.
Is it possible to coat the underside of the floor with something? I was wondering about spray on foam which will be messy working upwards but, more concerning, is the increased risk of underside rust. Or could the foam improve the rust resistance? :roll:
GBW
Re: Floor thermal insulation.
Postby Beaker » Fri Dec 29, 2017 9:50 pm
Not sure that's a realistic option. What have you got covering the wood floor - carpet, lino?
I've got insulating foam sheet between the van floor and the plywood floor sheets, them lino on top.
If it's too much trouble to take the floor up, I'd just fit carpet or rugs - simpler and cheaper than coating the underfloor!
2011 SWB medium roof 2.2l Mk7 115 T300 in Frozen White. Stealth Camper converted.
"It's better to burn out, 'cause rust never sleeps..."
Beaker
Postby john240758 » Fri Dec 29, 2017 11:22 pm
in mine got 12mm carpet underlay foam on top of ply and carpet on top warm and comfortable to walk on
john240758
Postby dumper » Fri Dec 29, 2017 11:59 pm
Just about to start my van number six the only thing I hav put under the ply wood is waxoil all I use on top of the floor is 4 t thin carpets just wear I walk at night after I have gone to bed rest of the time I’ve got shoes on and I use my vans all year as I write this I am parked up at Croft race circuit and snow is still on the ground
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby GBW » Tue Jan 02, 2018 10:01 am
The problem with the day solution of underlay is the arrangement for the bed support.
I can get round that but was looking for an easy fix.
GBW
