Anyone fitted a awning to mk 8
Re: Anyone fitted a awning to mk 8
Postby Lordduvet » Sun May 17, 2020 9:49 am
Dumper?
Got pics
I rejoined just to get the answer to your question
Lordduvet
Postby thebarber » Fri Jun 05, 2020 6:55 pm
Cheers for the heads up.
thebarber
Postby thebarber » Mon Jul 13, 2020 4:37 pm
Just bought this for £55 go outdoors
thebarber
Postby Altransit » Mon Jul 13, 2020 4:53 pm
thebarber wrote:Cheers for the heads up.
Never mind the awning, that van looks awesome in that colour 8) :mrgreen: :D
Postby Leemac20 » Wed Dec 23, 2020 12:50 pm
Hi all. I know this thread is nearly 3 years old, but faced with a similar challenge, I was wondering if anyone else had tried to fit a Fiamma awning to their MK8 recently? If so - what was your experience and was it worth it in the end?
I've got an L3 H2 (2015) and have been looking at the F80 fixed to the standard roof fixings if possible. Unfortunately like dumper back in 2018, it doesnt look like Fiamma have produced any adapters for this model. Any advice from others who have looked into this would be appreciated. Many thanks.
MK8 (2015) L3 H2 (FWD)
Leemac20
Postby DJ-JP » Sun Mar 07, 2021 6:35 pm
Tipperolly wrote:Success! Finally fitted the f45s today, I had to get some fiat roof mount brackets modified but now it just bolts straight into the roof rack mounts
Hi mate, I know this was from a while ago but could you specify which Fiat bracket you adapted so I could buy the same to adapt. Thanks.
DJ-JP
Postby JamesHow » Fri May 14, 2021 10:27 pm
Tipperolly wrote:
Do you have any inside pics of your camper conversion?
I'm about to start a simalar day van / lite conversion.
Cheers James
JamesHow
Postby dumper » Fri May 14, 2021 10:49 pm
Leemac20 wrote:Hi all. I know this thread is nearly 3 years old, but faced with a similar challenge, I was wondering if anyone else had tried to fit a Fiamma awning to their MK8 recently? If so - what was your experience and was it worth it in the end?
John Cooper at. Scunthorpe fitted mine on aL4 he used a extra bracket in the middle as mine is longer then the roof of the van.they bolt straight to the side of the roof and it’s reinforced insid the van 01724 850888
sales@johncoopers.com
Postby Rob62 » Sat May 15, 2021 6:37 pm
Hi dumper, which fiama awning did they fit? Type and length?
Cheers.
Rob
Rob62
Postby dumper » Sun May 16, 2021 7:27 am
From memory it’s a f40 & 5 m long it goes from about a foot in front of the curved part of the roof to about 6 inch from the rear of the van it’s a bit long really bit it was the only way to get it to cover the sliding door I will see if I can get a photo up on here and find the exact model.
Postby dumper » Sun May 16, 2021 9:08 am
dumper wrote:From memory it’s a f40 & 5 m long it goes from about a foot in front of the curved part of the roof to about 6 inch from the rear of the van it’s a bit long really bit it was the only way to get it to cover the sliding door I will see if I can get a photo up on here and find the exact model.
No it’s a F45s try putting photos up but not working
Postby Rob62 » Sun May 16, 2021 7:56 pm
Cheers dumper, I thought the f45 was the best option.. The worry I have is the lack of specific brackets for the mk8 but i have seen photo’s of them fitted. Do you know if they used standard fiamma brackets or if they had to modify or make their own?
Rob.
Rob62
Postby dumper » Mon May 17, 2021 5:49 am
Yes standard ones I tried one local dealer who couldn’t be bothered but John Cooper at Scunthorpe was very helpful they supply and fitted it no problem I went in the with the van for them to have a look and they got all the fittings and the awning and did it the next week.
Postby Rob62 » Mon May 17, 2021 11:54 pm
Cheers dumper, I was planning to fit one myself but I might give them a go instead...
Rob62
Postby dumper » Tue May 18, 2021 9:45 am
3 years ago it was about £855to £900 ish
