Crew van conversion
Crew van conversion
Postby Honda415 » Sat Apr 14, 2018 4:16 pm
Ok gents a few questions.
Got some old ldv minibus seats i want to put into the van hows best to mount them?
What size reinforcement plate/spacers are required to ensure the bolts dont pull through in case of any incidents.
What bolt and nut size and thread should i use to secure through the floor?
Also as i have a steel bulkead which will be removed will the overhead storage strength be compromised when i remove it?
Thank you for any advice ash
2006 Mk6 115 T350 Jumbo to be a workhorse once it works then potential motocross van.
Honda415
Re: Crew van conversion
Postby mistericeman » Sat Apr 14, 2018 5:09 pm
Bulkhead removal shouldn't affect the over cab shelf... Least it hasn't on our Ex mess bus Jumbo camper.
mistericeman
Postby Noctule » Sat Apr 14, 2018 5:26 pm
The seats in the hicube minibus (which itself was professionally converted from a van) we converted had plates underneath which measured approx 50mm square and 3mm thick, with 10mm bolts. If it's LDV seats you have they're likely to have 10mm bolt holes in them, but to be sure I would fit them with the biggest bolts that will fit, and get at least 10.8 tensile strength.
2000 Mk5 2.5 TDI HiCube DRW self-build camper, Bosch injector pump conversion
2006 Mk7 115t350 van
1987 Eagle Quest (Vauxhall Carlton Hearse, it's on ebay if you're interested...)
Previously...
Mk5 100 swb Custom (had mk4 engine!)
Mk5 190 lwb x3
Noctule
Postby Honda415 » Sat Apr 14, 2018 11:47 pm
Thats great gents thanks for the info i can work with that. Has anyone ever fitted the L shaped cargo system you find in newer minibuses? Nice install by the way
Honda415
