12V Led wiring
12V Led wiring
Postby Tcollings » Tue Jul 31, 2018 3:59 pm
Hi guys,
I'm wiring up some 12v lights in the back of my camper conversion. I've got a twin 12v switch with 3 prongs. I wired it up and have tested it today but when the switch is switched off, the postive wire gets very hot. I am just testing it at the moment so haven't connected the fuse box yet but it will defintely blow a fuse. I admit I dont fully understand the switch. The 3 terminals are for postive in, positive out, and earth. Why does the switch need to be earthed? When I remove the earth terminal from the switch the cables stop over heating? If anyone has any info that would be great!
Thanks a lot,
Tom
2001 mk6 LWB Duratorq 2.4L RWD
Tcollings
Re: 12V Led wiring
Postby twin wheel camper » Tue Jul 31, 2018 4:08 pm
Are you sure on the 3rd pin isn’t for switch illumination?
twin wheel camper
Re: 12V Led wiring
Postby imageoven » Tue Jul 31, 2018 11:10 pm
Show us a picture of the switch and how you wired it up.
imageoven
Re: 12V Led wiring
Postby hectors-tranny » Wed Aug 01, 2018 10:14 am
Yes as said above, switch needs to be earthed if it consumes electricity itself, i.e. has an indicator light.
hectors-tranny
Re: 12V Led wiring
Postby Spike_M » Sun Aug 26, 2018 5:43 pm
Probably a bit late on this one but I would guess its a SPDT switch
So pins 1&2T are normally open with 1&1T normally closed and vice-versa when switch is thrown.
If this is the case you only need 12v in and out to leds, no chassis ground.
Spike_M
