Transverse Bed
Transverse Bed
Postby parko58 » Thu Sep 27, 2018 3:44 pm
Hi New poster after a bit of advice.
I have the option to buy a decent priced low (60k) milage 2014/5 Transit L3H3 for conversion to a camper.
I would like to have a raised bed, transverse over a garage at the back. However I see that DVLA regs state that there should be a bed 6' or 180cm to qualify as a camper. I appreciate that they are unlikely to turn up with a tape measure but, as the internal payload width is recorded as 1784 how is this overcome?
I would be grateful for comments from members that have successfully managed to achieve this.
Many thanks
parko58
Re: Transverse Bed
Postby loot » Thu Sep 27, 2018 4:03 pm
Few options.
1. State this to them and see if they accept it as it is near as damn it. Honesty is the best policy and all that.
2. Arange it as a standard camper setup so you can change it then you can do what you like.
3. Put your number plate on the same van which is a camper and send that off to dvla to get it changed as a camper.
4. Cut 2 holes in the side for your feet. :lol:
Ids map here
loot
Re: Transverse Bed
Postby dumper » Thu Sep 27, 2018 4:34 pm
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Transverse Bed
Postby hectors-tranny » Thu Sep 27, 2018 5:05 pm
parko58 wrote:Hi New poster after a bit of advice.
Many thanks
Got some info on this for you Parko... I've recently converted a Mk8, and was concerned about the same issue. So I phoned the DVLA and they told me categorically that they do not impose a minimum 6 foot limit of beds. This concerned me as it's all over the internet, so I phoned them again a couple of months later and spoke to someone else. They said the same thing - doesn't matter about size of bed. Anyway, whether you believe those people or not, it is all over the internet, and it is always a possibility that insurers might use conversion specs to wriggle out of a claim. So what to do?...
In the end I set the height of my transverse bed so the top of the cushion aligns with the bottom of the rear window recesses. This enabled our bed to be over 6 foot in length. See pics.
Hope that helps - HT.
hectors-tranny
Re: Transverse Bed
Postby parko58 » Sat Sep 29, 2018 3:13 pm
Thanks all for the replies. Surely we shouldn't doubt the word of a civil servant :lol: Agree with you though about insurers probably less trustworthy than civil servants!
Having had a trawl round the message boards and with these answers I feel fairly positive that it can be done. If all else fails maybe the Flarespace option (if the lotto comes in) http://www.flarespace.com/#/home
Seeing the van tomorrow and if I go ahead will keep you posted.
Thanks again
parko58
Re: Transverse Bed
Postby Louey » Wed Oct 03, 2018 3:55 pm
My bed isn't quite six foot and I didn't tell that to the DVLA - the bed when out looks like a big enough bed and I think that suited the DVLA okay. You should be okay with the transverse setup.
Louey
Louey
Re: Transverse Bed
Postby dumper » Wed Oct 03, 2018 5:15 pm
It’s one of the daft camper van rules the same as having to have a fixed table or fixed mounting for a removable table every van conversion I’ve done for myself I’ve fitted the table and never used it as a freestanding table is more practical in a panel van conversion I use it outside the van as well
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Transverse Bed
Postby hectors-tranny » Thu Oct 04, 2018 11:43 am
dumper wrote:It’s one of the daft camper van rules the same as having to have a fixed table or fixed mounting for a removable table every van conversion I’ve done for myself I’ve fitted the table and never used it as a freestanding table is more practical in a panel van conversion I use it outside the van as well
^ What Dumper said.
hectors-tranny
Re: Transverse Bed
Postby straydog » Fri Oct 05, 2018 9:53 am
I have a Mk7 Jumbo with a transverse bed.
Just told dvla it was 6ft long (Which it is ;) )
Accepted my application for motorhome without problems.
Checkout my Youtube if you want to see the bed set up (9.05 min into vid)
https://www.youtube.com/watch?v=awh4mzWpcn0&t=301s
CVD :-)
straydog
Re: Transverse Bed
Postby parko58 » Mon Oct 08, 2018 7:07 am
Thanks Straydog, van and bed looks great. I have taken the plunge and bought the van and having taken the plywood off the side we actual measured the width at 1950 mm (outer wall to outer wall) so that gives us a bit of wiggle room. From that point of view very happy. However all the other decisions and my lack technical knowledge will make this a challenging build. The forum can expect a lot of questions!
parko58
