Tazsbus1991 wrote:Can you change them without taking the hubs off
Sent from my SM-G930F using Tapatalk
Yes just remove the drum is all that is required.
Make sure and back the handbrake cable if the drum is difficult to remove and also MAKE SURE AND MARK THE DRUM SO IT GOES BACK ON IN THE EXACT SAME PLACE
use tipex or you can just scratch the drum and a stud, if you don’t you will probably get bad brake judder
I didn’t mark mine and had to remove both nearside wheels and drum 4 times before I got the drum back on in the correct place
mine is a twin wheeler so was a major pain driving bad judder back home remove both rims on nearside drum off and turn the drum a single stud turn then back on then drive it still judder so on the 4th try got it back to no judder
thank fu** I only had one side off or I probably would never have got it judder free
