Hi ive been converting my 2011 2.2 MK7 lwb hi roof transit and need some advice please.
this van was an ex network rail van but was stripped of all the usual stuff inside ( inverter heater water heater sinks etc etc.
I still have the 2 batteries under the drivers seat, one starter and one leisure battery. There is also a buzz bar in the battery compartment with 100 and 60a fused links these still have cables running to them but as all the gear was removed i will be disconnecting them once i know which ones are not needed anymore or have been cut with the equipment removal.
I also want to run a second leisure battery and place at rear of the van and put in a victron ip22 smart charger for when im on 240v hook up so all batteries get charged.
can anyone tell me;
1, if my van has a smart alternator?
2 if i have or have not which way is best to do what i want above?
Cheers
