VSR wiring size advice please
Postby truxx » Sat Sep 14, 2019 11:18 am
Hi.
I'm fitting a leasure battery at the rear of my van so I bought a durite split charge relay from ebay...
Problem is that the cable from the starter battery to the LB is the same size as the vans battery wiring (very thick) but durite VSR terminals only seem to accept smaller 16mm2 (100a) cable.
Can I use the thicker cable from starter batt to LB compartment into a fuse block then use the smaller 16mm2 cable from that into the VSR and into the leasure battery?
Reason I'm using the thicker wire is because it was already run to rear of van to power a chair lift (ex mobility van) .
Appreciate any advice.
Dave
truxx
Re: VSR wiring size advice please
Postby dumper » Sat Sep 14, 2019 4:59 pm
Yes it’s only the same as if you had connected straight onto the battery terminals
Postby truxx » Sat Sep 14, 2019 7:15 pm
dumper wrote:Yes it’s only the same as if you had connected straight onto the battery terminals
Cheers for the reply dumper.
It seems pretty obvious really now that I thought about lol but was worth checking.
Thanks again.
Dave.
truxx
