Compressor fridge wiring
Postby muddybootson » Thu Oct 03, 2019 11:59 pm
Hi, I'm installing my compressor fridge at the front of my van, the leisure battery is at the rear, I was thinking of earthing the fridge where it stands rather then running the earth all the way back to the leisure battery, well this be OK? Cheers
muddybootson
Re: Compressor fridge wiring
Postby Airthies » Sun Oct 06, 2019 10:20 am
You can but I reckon your better to run twin cable if your going to run one anyway.
Personally chassis earth is a cheep construction method used by manufacturers. Which in certain areas can cause corrosion and resistance issues in the future.
Sent from my Armor_6E using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby thebarber » Sun Oct 06, 2019 3:45 pm
12v or inverting?
I'm contemplating both for my van
thebarber
Postby hectors-tranny » Tue Oct 08, 2019 12:24 pm
If you are running a longish cable between your battery and fridge, don't forget to factor in voltage drop over the cable length when you decide what size to use.
There's a calculator here: https://www.12voltplanet.co.uk/cable-si ... ction.html
hectors-tranny
Postby fink » Tue Oct 22, 2019 4:54 pm
Depends on what else you are installing. I usually run them back or loop in to an already established earth point.
fink
