fiamma zip
fiamma zip
Postby lcbandit » Wed Dec 11, 2019 4:42 am
Hi all
I have purchased a 2nd hand fiamma zip canopy with the privacy room, it comes with the basic fitting plates but as the roof on my lwb high top curves it looks like i will have to buy the fixing kit specific for my van, my question is this, has anyone fitted these using rivnuts or tex bolts? As my van has all the insulation now fitted and taped with the vapour barrier and then the ply on top it isn't an option to bolt all the way through using the fixing kit provided. Ideally could do with finding someone who could fit it that knows what they are on with :lol:
cheers
mandy
mk7 2013 plate :D
lcbandit
Re: fiamma zip
Postby loot » Wed Dec 11, 2019 9:12 am
I haven't but I would be more inclined to use rivnuts, you could dip them in pu18 or something oil based to help keep rust away from the drill hole. Plus there's less chance of ripping the metal on threads like with a tech screw.
Ids map here
loot
Re: fiamma zip
Postby dumper » Wed Dec 11, 2019 4:47 pm
I have had the F45 fitted to my van and had to be reinforced inside the van it has a extra middle mounting point it was fitted by a dealer and without the reinforcements it was twisting the side of the van mine been the Wind out type may be heavier and put mor strain on the roof all of friends of mine with awnings have had them reinforced
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: fiamma zip
Postby Airthies » Wed Dec 11, 2019 11:42 pm
I wouldn't mount anything substantial without reinforcing. The van panels are too thin to take any leverage force generated by something like an awning.
Your best to consider where exactly you want the mounts, cut appropriate access on the inside for reinforcing and then re insulate and reseal the vapour barrier and then make a feature of areas somehow?
Just remember to work out where the roof reinforcement sections are so you avoid those will stop you getting to the inside of the outer skin.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: fiamma zip
Postby thebarber » Sat Feb 01, 2020 1:50 pm
I'm looking at building a rack to fix solar panel and possibly take a fiamma.
Don't particularly like the usual builders racks so found Bosch Rexroth aluminium profiles.
Check em out ....
https://www.part-on.co.uk/fabrications/
thebarber
