Garryr wrote:Hi Ashlemon
I am thinking of getting the second row tourney seats, in my 2018 L1 H1 van, when you say hard to fit, what problems did you incur, I know the fuel thank has to be dropped etc: your experience would be much appreciated.
With these seats there are two rails per seat each containing 5 bolts. All three seats stretch across the whole van so you have many obstacles in the way to over come.
The driver side is easy, you get under there and see all the space you have, the middle seat 1st rail requires you to lower the exhaust and remove the heat guard (simple) to get the holes drilled and bolted in place. 2nd rail middle seat and 1st rail passenger side seat are really tough, the fuel tank needs to come off and it's big so ensure it's as empty as you can get it. Then you will need to be cautious with the hole positioning as you are really close to the main frame work, you'll need to position the rails so each hole gets a clean run through the floor and is accessible on the under side, whilst keeping the spacing correct so the seat goes in. We had to grind some welded nuts from the underside which initially I wasnt happy about but when they came off I realised they were meaningless.
Photo is recent as I've just laid the flooring
Sent from my SM-G960F using Tapatalk
