Fitting a Battery to battery Charger on a 350
Postby AmyH » Tue Apr 14, 2020 12:45 pm
Hiya,
I recently upgraded my van from a 2006 T260 to a 2016 350 and have moved across all the stuff from my conversion nice and easily. I’ve been advised however that I can’t use the old VSR system I had to charge my leisure battery and am looking at the Votronic 12V/12V 30A Battery-to-Battery Charger (VCC 1212-30).
The question I have is about the D+ connection to the alternator. How do I know where to connect this on a Transit 350 alternator and is there an easy was to access it?!
Thanks in advance
AmyH
Re: Fitting a Battery to battery Charger on a 350
Postby Airthies » Wed Apr 15, 2020 10:48 am
There's a run signal on newer vehicles, which is a signal from the PCM it will be listed in the BEMM for your van which you can download from the etis website.
The BEMM will also give lots of other useful info about installing anything into the van. They are a brilliant and comprehensive bit of literature.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Wed Apr 15, 2020 10:51 am
http://www.etis.ford.com/bemm/bemmAccep ... epted=true
V86+patch
V86.04
X-Prog
C81
Airthies
