Hello all -
I've just recently purchased a Mk8 highroof transit for campervan conversion and have discovered a couple of rust points on the roof (looking from inside) which appear to be cracked right the way through the roof panel. The roof has clearly received a bit of abuse as some of the support struts have come away from the roof panel itself in places. What would be my best approach to getting a good repair job done on this considering I'll be inulating and cladding from the inside so obv can't afford any leaks whatsoever?
I'm looking at rust treatment products such as FE 123 https://www.rust.co.uk/product/cat/fe-123-rust-converter-10 but am unsure whether this is the best approach considering the cracks break right through the panel and therefore may need to take more drastic action eg cutting and welding.
Any advice much appreciated.
