My son has a 2015 Ford Transit H3L3 which he has started converting to a camper van. We are learning as we go!
The van has two batteries under the drivers seat and a 240V three pin socket, which doesn't appear to work, underneath the handbrake. There is a single 60A customer connection point to the side of the drivers seat.
He has bought a 180Ah Varta leisure battery but is unsure how best to connect this so that it is charged from the alternator when the engine is running.
Opinions seem to vary. Some say use an automatic charge relay in the positive line, connecting to the existing service battery. Others the same but connecting to the starter battery. I'm favouring using a B2B (battery to battery) charge controller, such as this Votronic device (https://www.12voltplanet.co.uk/votronic ... 12-30.html). But can this be connected to the customer connection point, or must it be connected to the starter battery?
He may want to add a solar panel at some point in the future if this affects the best approach to take now.
Any advice gratefully received.
