Hi all,
New to the forum. Converting a Mk7 T430 17 seat minibus into a camper.
I’ve come up to a bit of a stumbling block with the batteries. I have a 130Ah AGM leisure battery to install, with a Redarc 40A b2b charger with solar. I’ve had my first question answered which is that the front battery is disconnected from the started battery by a relay when the ignition is switched off. Couple of other questions though:
Which battery is it better to attach my charger to and why? I understand that there are user terminals on the back of the battery box, I can’t actually get into them for some reason, but I understand that these are attached to the aux (front) battery. My Redarc charger is also ignition controlled though and surely if I attach to the aux battery then the starter battery will then not benefit from the solar panels. That said I don’t know if the charger feeds the vehicle battery or not.
I also need to find an ignition feed. Presumably there will be one in the battery compartment since there is a split charge relay controlling the two vehicle batteries, is this correct and if not is there an ignition controlled user fuse connection anywhere I can tag it on to?
Thanks in advance for your help, I’ll get some pics up when I get a little further with it.
Kieren
