dumper wrote:Your biggest problem will be finding one when you get one it’s just unbolt it 5 boils on old one four on the new some say they are rib bolts I used torq bit if you can spray the bolts underneath with wd 40 a few times as for electrical connections they may have the same plug .
Gregas wrote:Hi, Did you manage to do this?
I'm looking at doing the opposite, mines been converted to the single seat and the dash has an extra part however I want the bench seat back and the flat dash.
