Hi,
I've mentioned this on my camper progress thread but reckon it may get more traffic here, so will repost my question.
I recently bought a van which has 2 x rubber mounted camper-van windows on the right hand side; one mid panel, one rear panel. On the opposite left hand side i have no windows, instead, i have a solid sliding door (mid) and a solid rear panel.
I'm thinking of swapping the mid right window to the rear left panel (so i would have matching windows on both sides), so want to know, if i remove the mid window on the right hand side, make a template and cut the exact shape from the rear left panel where the window would go... do you think this panel could be welded into the mid-left hole, rubbed down from the outside, filled and sprayed to leave a decent enough finish? Or do you think it would always be visible? Note that the appearance on the inside is immaterial, as it will be covered anyway.
Any input from anyone with welding experience would be appreciated.
